165 Mod Cranks(22t Up Front)
toyota200x
Can you get 165mm hussefelts? meh, anyway you'd need somewhere between a 14 and 15t, so depends whether you like a harder or lighter gear than the usual 18-12, or for the same gear you could use a 24-16. This would also let you use a rear freewheel and save the cost of a freehub. Although some mods (eg. levelboss) don't have enough clearance in the seatstays with a rear freewheel.
