Rim Width With Magura Evo Boosters
scousertrials
i run a 38mm Ronnie with my evo mounts. it is a good sized rim. the only downside is that i have to shave half a brake pad off to make them fit!!! i spent £18 on rock pads and had to shave half the material away >_<
You do know you can switch the mounts round to let you run the calipers slightly further out don't you? I was running evo mounts, cnc backings and brand new plazzies with a 38mm ronnie rim without any problems at all and i had loads of room to set it up with.
