New Products From Tensile
BikeDotStuffAtOnzaDotCom
I think that it needs to be 15t and under, and 19t and under. Having three is pretty pointless.
Say you have a 16t, you'd need the 19t and under, but in adding the extra three teeth, how much does the radius of the sprocket increase by? Surely it's not enough to warrant marketing three products.
I might be missing something out, but I'd imagine the radius would only increase by about 3mm, which wouldn't make any difference would it?
We have now designed a new extended arm which will take up to a 19 tooth. Now all you have to do is convince me that it will sell. Also do I do further consolidation to two sizes to cover the whole range or add this as a third one.
I'd buy a tensioner to fit a 18T
I don't really understand why you would need different lengths. The Rohloff doesn't come in different lengths does it? I presume it would be a 'max sprocket size' so a 19t one would work for anything smaller than 19t? Seems fair to me.
Make a rear freehub, which works and behaves like a front tensile/rear pro 2, but is for Mod spacing.
And crucially, has a disc mount! Like a cheaper version of a profile, but with a proper disc mount.
yea what he said!!
I've also been thinking about a new rachet that the pawls run in, rather than the flats for the pawls to grip on being vertical, they are leaning foward so even if you don't let it engage fully and the pawl is right near the tip of the rachet, is will slip down into the corner.
If I understand what you mean (which I *think* I do, but feel free to correct me!) this would lead to slower overall engagement, as the ratchet mechanism would be traveling forward as the wheel rotates, and then back into the engagement again. It would, however be stronger, if the ratchet ring design was substantial enough, but it would probably be weaker than the equivalent if not thought about correctly
Would a mod freehub be feasable due to the small sprockets you guys run? I suppose it's just about there, so with a bit of thought it could be done :)
Nah we'd just run larger rings up front if you couldn't fit a small sprocket on the rear. I'm sure you could get away with something as small as a 10tooth sprocket though if you needed too.
Can you explain Muels ratchet system? Sounds quite interesting, just doesnt make sense.
That's the normal one.
This one's Muel's idea.
As you can see with Muel's design the tooth has to be thinner and more stress accumulates at the edge I highlighted in my Paint diagram. Check the scales on the side and you can see that Muel's has a higher maximum stress value.
I'm actually really surprised you explained that so well, thanks alot!
First of all let me say that we are working on freehub designs and have been for a considerable time. There is very little new in conventional ratchet and pawl systems and "muels" design has been used before. We are working on one particular patentable idea at the moment and we have other design concepts as well. There are a lot of patents still in place on freehubs and you have to navigate through them. I would make it clear that nobody soon will be producing a cheap Chris King copy as their mechanism is patented until 2017.
I know cassettes usually go down as far as 11t, though it would be nice if it were possible to beef these sprockets up a touch.
Shaun has pretty much shown exactly what I meant in terms of the strength side of things, only far better than I could have done!
The engagement would be an issue though I would imagine. It would mean finding a compromise between how much skew you put on the ratchet teeth, and how many points of engagement you had.
More skew means less teeth for equal strength, meaning less, but stronger engagement
More teeth results in less skew, meaning 'normal' or reduced strength, but more engagement points
Hard to say without looking closely at it and doing some analysis though :)
I can see the pics now.
I was thinking more like the first pic, but less tall and more undercut.
The second one is sort of getting there, but it curves instead of being flat, and it's not undercut enough.
This topic is now closed to further replies.
