trials 123 Posted February 19, 2007 Report Share Posted February 19, 2007 hi every body i was just woundring how i would no if i had rounded my cranks puting my free wheel on as it was really hard and stiff to put the freewheel on Quote Link to comment Share on other sites More sharing options...
ben.richardson Posted February 19, 2007 Report Share Posted February 19, 2007 You probably wont have threaded the cranks as the freewheels are very hard to put on without any form of lubrication to the crank or freewheel is the freewheel on the crank now or has it got a bit of thread left? As you could sneak some grease down there. Quote Link to comment Share on other sites More sharing options...
Dan6061 Posted February 19, 2007 Report Share Posted February 19, 2007 A rounded crank arm wont affect the freewheel at all.If it's square taper, if it's rounded it'll be, well...round?If it's ISIS, then you've done a good job rounding it. Did you clean the threads before you fitted the freewheel? Quote Link to comment Share on other sites More sharing options...
trials 123 Posted February 19, 2007 Author Report Share Posted February 19, 2007 (edited) no i just put the freewheel striaght on and i didnt use grease or clean it but the freewheel come off the old crank really easy but it was really hard to put it on the new ones Edited February 19, 2007 by trials 123 Quote Link to comment Share on other sites More sharing options...
samo Posted February 19, 2007 Report Share Posted February 19, 2007 well there is only one way to find out realy. is to take it off but good luck mate Quote Link to comment Share on other sites More sharing options...
