Krisboats Posted February 25, 2007 Report Share Posted February 25, 2007 (edited) Am i wrong in thinking the distance between the rear axle and the brake mounts is roughly the same on mod bikes? Or are you trying to make it so it rests on the seatstay to spread the braking load out a bit more?I genuinely don't understand how it would be different between every type of frame so if someone could put me straight i'd very much appreciate it I guess this is how i imagined it would look, which i guess fits most frame shapes. Edited February 26, 2007 by Krisboats Quote Link to comment Share on other sites More sharing options...
Ducko Posted February 26, 2007 Author Report Share Posted February 26, 2007 (edited) first proto made,needs a few adjustments but this is close to the final design except for the support which isnt made yet also its strong as fook!EDIT: the third hole is for the bolt where the snail cam is extra support. Edited February 26, 2007 by craigdavies Quote Link to comment Share on other sites More sharing options...
Balman Posted February 27, 2007 Report Share Posted February 27, 2007 looks simple and effective how much will you retail them at? nice one Jack Quote Link to comment Share on other sites More sharing options...
mat hudson Posted February 27, 2007 Report Share Posted February 27, 2007 for an ashton stock cragger? Quote Link to comment Share on other sites More sharing options...
manuel Posted February 27, 2007 Report Share Posted February 27, 2007 EDIT: the third hole is for the bolt where the snail cam is extra support.surely the only support. without that bolt the thing would rotate round. and with the bolts being very close to the pivit point of the axle its going to recieve an enormous amount of force. maybe not enough to break it but all the same - I wouldnt want to risk it. so (like they say on dragons den) for that reason Im out. plus it wont work on a stock anyway . Quote Link to comment Share on other sites More sharing options...
RobinJI Posted February 27, 2007 Report Share Posted February 27, 2007 (edited) Just a heads up, but that mount wouldn't work with a Mono trials as the caliper would hit the material between the mouning wholes. Also on an I.S. disc mount the mount is 0.4mm setback from the dropout face (or in this case the part where the hub sits on the adapter.) (excuse my spelling, for some reason spell check doesn't work on this computer.)Manuel, he said that pic didn't include the support, so I'm guessing theres something that goes through the dropout and adapter behind the axle or something. Edited February 27, 2007 by Dont you Just Hate it When... Quote Link to comment Share on other sites More sharing options...
Ducko Posted February 27, 2007 Author Report Share Posted February 27, 2007 there is another support being attached that hasnt yet been made.again more pics will be up soon and this is a prototype!!cheers Quote Link to comment Share on other sites More sharing options...
pitbull-91 Posted February 28, 2007 Report Share Posted February 28, 2007 i will have one for a t-pro but make a bit that goes up and bolts to the maggie mounts that should work out to be stronger and wouldn't move as much or put as much stress on the frame.adam Quote Link to comment Share on other sites More sharing options...
liam-pantera Posted February 28, 2007 Report Share Posted February 28, 2007 wow that looks imense and afordable il deffo buy one btw is the hole 10 mm for a axel/profile bolt ?keep up the good work and il be one of you first customers . Quote Link to comment Share on other sites More sharing options...
Ducko Posted February 28, 2007 Author Report Share Posted February 28, 2007 that one is 10.2 slot, i will be making and adapter for people will ikkle bolts and axels Quote Link to comment Share on other sites More sharing options...
