Grips Rubber Or Foam ?
Z o o !!
do you prefer posts with a point or posts without a point?
you seem to have alot without a point
this topic doesn't seem so bad, there are way worse
he's just asking opinions and i bet some people could use this to decide if they want to get foam grips or rubber grips
I prefer rubber grips myself
But foam seems to be better if you ride without gloves
rubber i find alot more grip, foam last longer i think but i will never stop using rubber, my next set of grips will be a set of "Jimmy le van" grips they are super thin with an awesomely grippy cork style grip and flanges aswell
Foam grips seem to be quite good for trials, my buddy runs them and doesent seem to have many problems with them, although if your a sweaty bugger you might not want to run them, it'd be like glueing on sponges ;)
On the other hand, being a bmxer, i have to say that the amount of quality rubber grips out there really is quite shocking. There are so many of them, which are..
A) Long lasting
B ) Available in many different thicknesses, lengths, etc.
C) Cheap. Or cheap enough.
I would put in one of those "Do what you want" kind of quotes, but you came here for advice, so i gave it.
Cya.
Edited by Jedimindtricks
