python Posted February 18, 2007 Report Share Posted February 18, 2007 hi somebody told me if you have a monty ti you can't run a rear profile hub beacause it cracks or snaps your frame. Quote Link to comment Share on other sites More sharing options...
mrBENN Posted February 18, 2007 Report Share Posted February 18, 2007 I saw a guy riding comp today he was on a ti with a green profile and it had no problems with it and it rides fine so i dont think there is a problem with running a profile on a ti Quote Link to comment Share on other sites More sharing options...
danny_cartledge Posted February 18, 2007 Report Share Posted February 18, 2007 Your frame wont crack from riding a profile, aslong as you use your snail cams on the outside of the frame!Hope this helps Quote Link to comment Share on other sites More sharing options...
ftw Posted February 18, 2007 Report Share Posted February 18, 2007 Yes, use your snail cams on the outside and you will be A Okay. If you are using Profile that is? Ross Quote Link to comment Share on other sites More sharing options...
ogre Posted February 19, 2007 Report Share Posted February 19, 2007 it's 'cause monty used to make their rear drop outs slightly thinner (so you could only run monty hubs) beleive the 07 models have normal mod spacing Quote Link to comment Share on other sites More sharing options...
