Cracked Frame!
Onza-Trials
If your frame is cracked, you get it welded. It still used to be cracked, therefore it will be weaker, my friend had his frame welded twice in the same place, then it snapped again in the same place and another area, re-welding makes frames weaker.
haha i reck it made it a bit stronger to be honest
depends where it is init. mines safe
My advice would be to get a half price replacement. Welding frames is very inadviseable. In frame manufacturing heat treatment is essential after welding alloy and this perticular frame has two heat tretments which can only be carried out in strictly controlled factory conditions. Once you weld it again the frame will need to go through this process again. If not you will creat a worse stress point than the original one.
Phone Super Cycles and get a new one.
Cheers
