20inch_power Posted February 17, 2007 Report Share Posted February 17, 2007 hi people, my hope mono mini trials rotor is rubbing against my right hand pad (and making a really bad squeeky noise), i cant think y and how i can solve the problem.please help me solve the squeekeyness. cheers ...Suli... Quote Link to comment Share on other sites More sharing options...
D a n n y. . . Posted February 17, 2007 Report Share Posted February 17, 2007 (edited) oright your wheel might be in wrong set it up perfectly or the disc might be loose? Edited February 17, 2007 by bigez_91 Quote Link to comment Share on other sites More sharing options...
danny_cartledge Posted February 17, 2007 Report Share Posted February 17, 2007 Your rotor might be bent!Take your wheel out and spin it, you will be able to see if it is bentHope this helped Quote Link to comment Share on other sites More sharing options...
Mod Man Leo Posted February 17, 2007 Report Share Posted February 17, 2007 cheap, easy ,lazy ,ass ,awser here!!put up with it for like a week and the pad will have ajusted itself and worn down abit! nah, is your rotor buckeld? if not just caliper ajustment- it takes a while if you wanna do it write but its worth it!or is your piston "lazy"? Quote Link to comment Share on other sites More sharing options...
lawrence osborn Posted February 17, 2007 Report Share Posted February 17, 2007 if the caliper is to far one way?, put a small washer on each bolt were the caliper is if u know what i mean, it will move it over Quote Link to comment Share on other sites More sharing options...
sam-cahill Posted February 17, 2007 Report Share Posted February 17, 2007 Hi i had the same problem but with magurs martas.What it was with mine is that i had banged the disk and bent it very slightly so every time the tyre turned the disk hit the pad and squeked.Dont realy no how you can fix it but the aesist thing to do will be buy a new disk. Sam Quote Link to comment Share on other sites More sharing options...
20inch_power Posted February 17, 2007 Author Report Share Posted February 17, 2007 if the caliper is to far one way?, put a small washer on each bolt were the caliper is if u know what i mean, it will move it overthat is my next step i think.........my rotor is straight as a ruler....its in mint condition.......i might just sand my pads down a lil bit??cheers 4 comments......suli... Quote Link to comment Share on other sites More sharing options...
Blommah Posted February 17, 2007 Report Share Posted February 17, 2007 You need to put some washers between the frame and the brake on the two bolts so that the brake moves a bit out.Try different sized washers until you get it right. Quote Link to comment Share on other sites More sharing options...
20inch_power Posted February 17, 2007 Author Report Share Posted February 17, 2007 You need to put some washers between the frame and the brake on the two bolts so that the brake moves a bit out.Try different sized washers until you get it right.kk ill do that tomorow...cheers matey ...Suli,,, Quote Link to comment Share on other sites More sharing options...
