sam-cahill Posted February 17, 2007 Report Share Posted February 17, 2007 Hi i am just learning how to side hop and find it very hard so i was just wondering if there is any top tips any one has.Thanks alot. Sam Quote Link to comment Share on other sites More sharing options...
adam trials Posted February 17, 2007 Report Share Posted February 17, 2007 Rite when you approch the wall make sure you are at a 45(ish) digree angle to the wall. Do a small hop to build some momentum then pull up as high as you can then place the front wheel on the wal and swing your rear wheel up on. And there you go you can side hop. I know it is not a good description but if you use the search you will probably find some other topics about this, they may be more helpful.Adam. Quote Link to comment Share on other sites More sharing options...
Onza-Trials Posted February 17, 2007 Report Share Posted February 17, 2007 im sure there is the same topic on this if u looked Quote Link to comment Share on other sites More sharing options...
Richard jersey Posted February 17, 2007 Report Share Posted February 17, 2007 Approach the obstacle on about a 45 degree angle and make sure you have some space in front of you to skip-hop. Do a couple of skip-hops (however many you feel comfortable with). After this, crouch a bit to get spring, then lift your bike as high as you can and place the front wheel on the obstacle and use the front wheel as well as your momentum to lift the back wheel up. Once you have done this make sure you don't loose your balance and make sure you are firmly on the obstacle.Richard Quote Link to comment Share on other sites More sharing options...
chris-rider Posted February 17, 2007 Report Share Posted February 17, 2007 yes sam find another topic and look at them hahaha and why didnt u ask me to teach u wen we are up at the glen ??? Quote Link to comment Share on other sites More sharing options...
sam-cahill Posted February 17, 2007 Author Report Share Posted February 17, 2007 Ok thanks guys there all good and next time i will search and chris i did ask u for help but all you said was your doing it wrong thanks for keeping me on a high.Keep them coming the more the better. Sam Quote Link to comment Share on other sites More sharing options...
