Wright Pads Posted February 14, 2007 Report Share Posted February 14, 2007 Okay bit sad maybe i duno.Thankfully i have an empty bottle of JD, 70cl size. It was my bro fav and only drink...I want to cut the neck off. Just above where on the glass it has ''Jack Daniels'' cast in the glass.Why, well once i've cut it i'm going to smoeth it off and covered the lables with stick back plastic or try and find the full sized one online, laminate them and then use it as a varse at his grave side!I was wandering if i could cut it using a really thin blade for my angle grinder and high speed?Will be dusty as it's glass but i will have protection on i promiss....any tips or ideal?Pete Quote Link to comment Share on other sites More sharing options...
moto_psycho Posted February 14, 2007 Report Share Posted February 14, 2007 only advice i can give is take it slow, never cut glass before, so i wouldnt know what to expect Quote Link to comment Share on other sites More sharing options...
Wright Pads Posted February 14, 2007 Author Report Share Posted February 14, 2007 Slow at moving the grinder to cut it yeah but full speed with the disc that way you mean? It's what i had planed to do Quote Link to comment Share on other sites More sharing options...
Hendrix Posted February 14, 2007 Report Share Posted February 14, 2007 Wouldn't advise using some kind of mechanical run tool to cut it...get a thin hacksaw to do it, or you could end up blind, litterally... Quote Link to comment Share on other sites More sharing options...
danfox23 Posted February 14, 2007 Report Share Posted February 14, 2007 http://www.toolstation.com/index.html?r=a&...8a5fx7SH95760Dyi would suggest go out and but a glass cutting tool... and take it slow while cutting round the neck but make sure its a deep cut then you could knock it off.... i think Quote Link to comment Share on other sites More sharing options...
Wright Pads Posted February 14, 2007 Author Report Share Posted February 14, 2007 I haven't me car today as it's being serviced so i think angle grinder it is Quote Link to comment Share on other sites More sharing options...
Hendrix Posted February 14, 2007 Report Share Posted February 14, 2007 I haven't me car today as it's being serviced so i think angle grinder it isIt's go tits up if you do...seriously... not worth the hassle! Quote Link to comment Share on other sites More sharing options...
guineasmithpig Posted February 14, 2007 Report Share Posted February 14, 2007 be patient. personally, i'd find a company to do it for you. they have the necessary protection and procedures. glass dust is EXTREMELY dangerous. you need an extraction unit, not just a face mask and goggles!like they idea though. and it'd be worth doing it properly. a company could probably prep the cut edge nicely as well?smithy Quote Link to comment Share on other sites More sharing options...
Wright Pads Posted February 14, 2007 Author Report Share Posted February 14, 2007 If it does just means £18 out on a new bottle, up till 7am again and then a huge hangover! Good exucse really! Quote Link to comment Share on other sites More sharing options...
Hendrix Posted February 14, 2007 Report Share Posted February 14, 2007 If it does just means £18 out on a new bottle, up till 7am again and then a huge hangover! Good exucse really!and possibly death.... Quote Link to comment Share on other sites More sharing options...
Fishy Posted February 14, 2007 Report Share Posted February 14, 2007 I've tried to cut glass with an angle grinder. I advice you not to. Glass splinters, and flys everywhere. Either get a proper company to do it, or get a glass cutting tool. DO NOT USE AND ANGLE GRINDER. Quote Link to comment Share on other sites More sharing options...
CurtisRider Posted February 14, 2007 Report Share Posted February 14, 2007 and possibly death....its not that bad just a get a glass specialist to do it, its really not worth the risk, and you want it done properly Quote Link to comment Share on other sites More sharing options...
Wright Pads Posted February 14, 2007 Author Report Share Posted February 14, 2007 Done it! I used a title cutting blade at full speed and just let it rest it's own weight on the bottle. Everything was taped up really tight, tape split as i was tapping it it up. I made one and it came off clean pretty much. 3 tiny crack have formed but only in the top! Super gule has been used. Well Crayonlate thin toxic stuff but has filled them up and will stop them! Just found some clear acrlic spray in the atic so i have just given the bottle a cost misting with that to seal the labels. Will do it again once its dryed a bit. As for edge protection i'm using some 1/2'' hose that was spear form my water cooling on my pc! Cut a V in the corner so one length can be use. Some stone in the base to weight it down then fill with water add blue red blue flowers (his army unit colors) and take it down. Nice little tribute for him i think!Sorry guys i know i risked a lot, lossing the bottle or hurting my self but i really wanted to do this for him. Even though we hadted each other, never had anyhting in comen and fight cat and dogs.RIP brv you buggaWill post pics one it's dry Quote Link to comment Share on other sites More sharing options...
Krisboats Posted February 14, 2007 Report Share Posted February 14, 2007 Done it! I used a title cutting blade at full speed and just let it rest it's own weight on the bottle. Everything was taped up really tight, tape split as i was tapping it it up. I made one and it came off clean pretty much. 3 tiny crack have formed but only in the top! Super gule has been used. Well Crayonlate thin toxic stuff but has filled them up and will stop them! Just found some clear acrlic spray in the atic so i have just given the bottle a cost misting with that to seal the labels. Will do it again once its dryed a bit. As for edge protection i'm using some 1/2'' hose that was spear form my water cooling on my pc! Cut a V in the corner so one length can be use. Some stone in the base to weight it down then fill with water add blue red blue flowers (his army unit colors) and take it down. Nice little tribute for him i think!Sorry guys i know i risked a lot, lossing the bottle or hurting my self but i really wanted to do this for him. Even though we hadted each other, never had anyhting in comen and fight cat and dogs.RIP brv you buggaWill post pics one it's dryNo way, i didn't think a grinder would be capable of doing it. I would have suggested using something like a tile cutting tool with the super thing diamond blade and the water jet to stop the glass heating and cracking and to stop the dust becoming airborne.Guess its too late to mention it now though, well done for managing it. Quote Link to comment Share on other sites More sharing options...
Walleee Posted February 14, 2007 Report Share Posted February 14, 2007 Done it! I used a title cutting blade at full speed and just let it rest it's own weight on the bottle. Everything was taped up really tight, tape split as i was tapping it it up. I made one and it came off clean pretty much. 3 tiny crack have formed but only in the top! Super gule has been used. Well Crayonlate thin toxic stuff but has filled them up and will stop them! Just found some clear acrlic spray in the atic so i have just given the bottle a cost misting with that to seal the labels. Will do it again once its dryed a bit. As for edge protection i'm using some 1/2'' hose that was spear form my water cooling on my pc! Cut a V in the corner so one length can be use. Some stone in the base to weight it down then fill with water add blue red blue flowers (his army unit colors) and take it down. Nice little tribute for him i think!Sorry guys i know i risked a lot, lossing the bottle or hurting my self but i really wanted to do this for him. Even though we hadted each other, never had anyhting in comen and fight cat and dogs.RIP brv you buggaWill post pics one it's dryoh my god can't wait Quote Link to comment Share on other sites More sharing options...
Wright Pads Posted February 14, 2007 Author Report Share Posted February 14, 2007 I had the bottle on the flor then folded a tick cardbord box over it so it wasn't going to kill me if it went pete tong. 2nd coat on now then the edging then it be done... Quote Link to comment Share on other sites More sharing options...
Wright Pads Posted February 14, 2007 Author Report Share Posted February 14, 2007 Done! Going to fill with marbles and use some artificall flowers we got as they will last longer! Pretty cool i think! Quote Link to comment Share on other sites More sharing options...
F-Stop Junkie Posted February 14, 2007 Report Share Posted February 14, 2007 Wow, that's a really bad cut... Looks more like you've smashed the neck off instead of cutting it. Quote Link to comment Share on other sites More sharing options...
JT! Posted February 14, 2007 Report Share Posted February 14, 2007 I would have just left it as it was, you still could have got flowers in it.Good idea though. Quote Link to comment Share on other sites More sharing options...
Krisboats Posted February 15, 2007 Report Share Posted February 15, 2007 To be fair guys, he is planning on covering the rough edge with hosing like he mentioned earlier, so the general appearance of the cut doesn't have to be good. I reckon if you are covering the edge with pipe though you might have wanted to leave a little bit more room above the JD writing because it'll cover it a bit with what little material you've left on it.Black label with orange glass marbles would look especially pimped. Quote Link to comment Share on other sites More sharing options...
Dan6061 Posted February 15, 2007 Report Share Posted February 15, 2007 We used to just stick candles in our old bottles. Quote Link to comment Share on other sites More sharing options...
Wright Pads Posted February 15, 2007 Author Report Share Posted February 15, 2007 Black label with orange glass marbles would look especially pimped.Cool idea there Kris, some nice dark kind orange. Didn't think of that. Ta Quote Link to comment Share on other sites More sharing options...
