mrBENN Posted February 14, 2007 Report Share Posted February 14, 2007 Hi people iv'e got echo lite forks, and from a couple of weeks ago, they have started creaking ive checked for cracks and there wasn't any does anyone have this same problem and is there any suggestions of what i can do to stop this happening?thanks for your helpBen Quote Link to comment Share on other sites More sharing options...
Synergy Posted February 14, 2007 Report Share Posted February 14, 2007 hey try tightening your headset or putting some grease on the steerer tube, i have the same forks and i think they just creak because they flex a bit compared to most forks. Quote Link to comment Share on other sites More sharing options...
mrBENN Posted February 14, 2007 Author Report Share Posted February 14, 2007 Thanks could it be becasue of the power of my disk or the thickness of the steering tube ? Quote Link to comment Share on other sites More sharing options...
RobinJI Posted February 14, 2007 Report Share Posted February 14, 2007 Have you checked the steerer for cracks too? or did you just check with the fork still in the bike? Quote Link to comment Share on other sites More sharing options...
mrBENN Posted February 14, 2007 Author Report Share Posted February 14, 2007 I removed the forks and no crakes i dont no what to do i mihgt get it re-greased and see if that makes a difference. Quote Link to comment Share on other sites More sharing options...
dave85 Posted February 14, 2007 Report Share Posted February 14, 2007 Don't know the situation now, but it used to be quite common that echo/zoo forks creaked. The steerer is pressed into the fork crown and welded at the bottom only. Over time, the crown stretches slightly and lets the steerer move a bit, causing the creaking. To check that, take the forks out, put the steerer in a vice (so that if you put a wheel in the fork, it would be lying flat on its side), grab hold of the fork blades and push/pull on them. Sometimes when there's been spare grease and oil lying about, you'll see it coming out of the joint as you push and pull, as well as the creaking. Its quite un-nerving having a creaking set of forks, but I know of pairs that started creaking at two weeks old, and went on to last another two years. Quote Link to comment Share on other sites More sharing options...
