BIGA1 Posted February 13, 2007 Report Share Posted February 13, 2007 How do you get the anodised coting off the metal (ie) cranks.cheers.Ashley Quote Link to comment Share on other sites More sharing options...
adam trials Posted February 13, 2007 Report Share Posted February 13, 2007 Why would you want to?Just use some sand paper or something but they will rust when it is off because it is like a protective layer over the metal.Keep it on.Adam. Quote Link to comment Share on other sites More sharing options...
padarik Posted February 13, 2007 Report Share Posted February 13, 2007 How do you get the anodised coting off the metal (ie) cranks.cheers.Ashleycoustic soda in hot water works mint did my cranks and rims init , can get it from b n q for bout 4 pounds, its ment for unbloking drains , but works a treat , be carefull though it can be very corosive to skin hope iv helped padarik Quote Link to comment Share on other sites More sharing options...
Ash-Kennard Posted February 13, 2007 Report Share Posted February 13, 2007 Why would you want to?Just use some sand paper or something but they will rust when it is off because it is like a protective layer over the metal.Keep it on.Adam.it wont rust, it will oxidize as it will be aluminium. Nitromors will probably do the trick Quote Link to comment Share on other sites More sharing options...
BIGA1 Posted February 13, 2007 Author Report Share Posted February 13, 2007 Why would you want to?Just use some sand paper or something but they will rust when it is off because it is like a protective layer over the metal.Keep it on.Adam.I'm going to laker my cranks after i get the Anodis off. Quote Link to comment Share on other sites More sharing options...
adam trials Posted February 13, 2007 Report Share Posted February 13, 2007 it wont rust, it will oxidize as it will be aluminium.Sorry my bad i thought it would rust lol.Adam. Quote Link to comment Share on other sites More sharing options...
padarik Posted February 13, 2007 Report Share Posted February 13, 2007 it wont rust, it will oxidize as it will be aluminium. Nitromors will probably do the trick nitromors wont do feck all to anodising, just use coustic soda, poor it in a plastic tub add hot water put cranks in , 1 min later bang done. no need for any one else to put anything, this is the easyest way! Quote Link to comment Share on other sites More sharing options...
Wright Pads Posted February 13, 2007 Report Share Posted February 13, 2007 For a cheaper and faster effect wire bursh thingy in the end of a drill and go nuts on them!!! It'll get it off and layer of the aluminum that has oxerdized before the anodizing and you can then polish them up to bling all in half hour Quote Link to comment Share on other sites More sharing options...
Krisboats Posted February 13, 2007 Report Share Posted February 13, 2007 For a cheaper and faster effect wire bursh thingy in the end of a drill and go nuts on them!!! It'll get it off and layer of the aluminum that has oxerdized before the anodizing and you can then polish them up to bling all in half hourYep he's pretty much right. Even if you do use caustic soda i would still recommend to sand /wire brush the surface of the parts so as to allow for maximum effect when cleaning them up before you lacquer them. Quote Link to comment Share on other sites More sharing options...
Joe Sheehan! Posted February 13, 2007 Report Share Posted February 13, 2007 DO IT OUTSIDE WITH A MASK!!!Sorry for the capitals but it can suffocate you if you do it in a non-ventilated area! Safety first guys! Quote Link to comment Share on other sites More sharing options...
Wright Pads Posted February 13, 2007 Report Share Posted February 13, 2007 Eye protection too and gloves if using the soda Quote Link to comment Share on other sites More sharing options...
JsyJoel93 Posted February 14, 2007 Report Share Posted February 14, 2007 (edited) coustic soda in hot water works mint did my cranks and rims init , can get it from b n q for bout 4 pounds, its ment for unbloking drains , but works a treat , be carefull though it can be very corosive to skin hope iv helped padarikThis topic's been really helpful as i wanted to do it myself and caustic soda seems to be the way to go but "Padarik" when you did your rims, where they built up wheels or just new rims without spokes and hubs ?CheersJoel Edited February 14, 2007 by JsyJoel93 Quote Link to comment Share on other sites More sharing options...
kyle-livesey Posted February 14, 2007 Report Share Posted February 14, 2007 coustic soda but dont leave it in to long as it wears away layers of metal and they wont fit proply and its very nasty stuff Quote Link to comment Share on other sites More sharing options...
padarik Posted February 16, 2007 Report Share Posted February 16, 2007 This topic's been really helpful as i wanted to do it myself and caustic soda seems to be the way to go but "Padarik" when you did your rims, where they built up wheels or just new rims without spokes and hubs ?CheersJoel sorry for bump :$ i had them as rims only not built up . id not worry bout leavin your cranks in to long, it would take hours for it to get to the metal just wear gloves and maybe eye protection just incase, an ice cream tub would be perfect to have them in . the soda does nothing to paint or plastics from my recolation so any plastic tub really hope iv helped padarik Quote Link to comment Share on other sites More sharing options...
