Adamant '07
Matthew_Gibson
Got it built friday, and I love it. BIG thanks to the guys at tartybikes for the very speedy delivery! (Y) Its the long and measures in at about 1097(ish)
Spec:
Adamant '07 long
Fatty R forks
HS-33 rear '06Alic Pads (there ace!)
Zoo! Bars
Pazzaz
Front - Hope XC, Echo rim(custom painted :P ), Maxxis High Roller 2.35
Rear - Hope ProII, Onza Ronnie rim, Maxxis Minion 2.35
Middleburn cranks
SKF BFR-300
Avid Ball Bearing 7 - 185mm
Shimano XT lever
Foam grips
KMC chain
FSA Orbit Equipe Headset
DMR V8's
EDIT!
Painted the forks, looks really good, VERy pleased with the finish!
Need to get Grips. and finish building it to for the easter hols! Then NEW VID! opefully if im not under pressure with school work
Edited by Matt Gibson
  • 1 month later...
Get your self a dedicated chain tensioner and some better stoping power on the front as cable disc is a bit sill for trials in my experience!!
Avid is better than a magura front disk in my experience! AND if u had bothered to look at my newest post, you would have seen i run a £50 tensioner! and there was nothing wrong with my old mech. just bent it.
