bowman12 Posted February 10, 2007 Report Share Posted February 10, 2007 (edited) i ride a giant trials team, and as most of you will know, they only have a 2 bolt fitting due to it being an OLD SCHOOL frame.the frame flexes really badly and ive been wanting a booster for a while, i've found one that will fit the width of the frame but it says - For use with the upper two bolts of dedicated 4-Bolt Magura mounts.will they still fit on the 2 bolt fittings on my EVO mountings on my giant??? Edited February 10, 2007 by bowman12 Quote Link to comment Share on other sites More sharing options...
Dan6061 Posted February 10, 2007 Report Share Posted February 10, 2007 (edited) Nope.You need a V brake booster. Like this - http://www.tartybikes.co.uk/product.php?id=13 Edited February 10, 2007 by Dan6061 Quote Link to comment Share on other sites More sharing options...
ogre Posted February 10, 2007 Report Share Posted February 10, 2007 you could probably fit a 2 bolt booster onto evo mounts as well (you'd probably need it evos are flexy as fook) Quote Link to comment Share on other sites More sharing options...
flas12345 Posted February 10, 2007 Report Share Posted February 10, 2007 a 2 bolt booster will fit onto your evo mounts for certain. my mate put one on today and it works a dream(also a 4 bolt one would work aswell). now the frame does not flex at all.cheers lou. Quote Link to comment Share on other sites More sharing options...
Tango Posted February 10, 2007 Report Share Posted February 10, 2007 It should fit because the bolts at the top of a evo mount are the same bolts that the four bolt mounts use. I also cut up a 4-bolt mount into a 2-bolt on and it worked a charm on my base. Quote Link to comment Share on other sites More sharing options...
bowman12 Posted February 10, 2007 Author Report Share Posted February 10, 2007 (edited) a 2 bolt booster will fit onto your evo mounts for certain. my mate put one on today and it works a dream(also a 4 bolt one would work aswell). now the frame does not flex at all.cheers lou.thats cool. i'll order one off tarty on monday. that way i can get it before half term and get some good riding in. also, will the tensile 4 bolt mounts fit in the evo mountings? i dont want to spend £18 on pads that i have to sand down due to the size of my rim Edited February 10, 2007 by bowman12 Quote Link to comment Share on other sites More sharing options...
Tango Posted February 11, 2007 Report Share Posted February 11, 2007 no they wont but if you find some old evo mounts there offset a little Quote Link to comment Share on other sites More sharing options...
padarik Posted February 11, 2007 Report Share Posted February 11, 2007 if you can set the brake up perfect with the top to mounts bein 100 mm apart then yeah you could use a 2 bolt booster . just put 2 evo boosters on the top so its really thick and then run a v booster shell be fine. will need to get slightly long m5 bolts for the top evo mounts Quote Link to comment Share on other sites More sharing options...
