Advice Needed - Improving Maggy On A Medium Grind
Phil H
I've always ran tar and a smooth rim however I got a new wheel second hand and its got a medium to light grind. I tared it up a tiny bit then had a little rride but it started slipping badly, clearly the tar wasnt helping and was foolish. However even with the poor pads I have (red onza ones) and a medium grind I expected more.
Has anyone got any short term Ideas so I can be out and about tomorrow. I have about 1g of tar left and if its wet that'll be useless.
Its horrible and depressing but im seriuosly considering putting coke on it or something else suggary because there is no way I can sort out a new grind or get new pads by tomorrow :S
Any Ideas? :)
Cheers, Phil
O.K cheers guys. I'll just have to make do. The tar is just about possible to apply, if it rains I just won't ride (Y) (and be pissed off)
Phil
If its rains take ur bike out and ride with the brake on till all the tar is all smudgy and get some toilet roll/kitchen roll and jus wipe it off. Its what i do anyway.
Rorz!
seconded what ash says, tar on a grind just doesn't work to be honest i'm surprised you could even apply it.
How cant you apply it? lmao, it's well easyer than with a smooth rim, a grind grabs/grips the tar like a pad would to make a better brake.
Mat
Mat
sorry but your wrong, either that or you can't gring a rim, when you rub the tar round te rim it just flakes off, kind of like grating cheese. The bits that do stay on are clumpy and get caught between the grind ridges. So when you brake your pads stick.
How f**kin hard do you have your tar :S like a rock? it's supposed to be abit soft, not f**kin rock hard. else yeh... it will flake off, and i dont see how it would be easyer to apply to a smooth rim if its hard as a rock :S.
Mat
