t-liteboy Posted February 5, 2007 Report Share Posted February 5, 2007 hi there, i was wondering what the stages are to bleeding with water in a bucket and how i get it perfect.how do i add anti freeze please coment and give me you edvise to a perfect bleed.cheersjake Quote Link to comment Share on other sites More sharing options...
Louth Trials Posted February 5, 2007 Report Share Posted February 5, 2007 (edited) hi there, i was wondering what the stages are to bleeding with water in a bucket and how i get it perfect.how do i add anti freeze please coment and give me you edvise to a perfect bleed.cheersjake Right here goes, this is how i do it and get a perfect bleed everytime; Tools needed:.5mm allen key,.3mm allen key,.Bucket,.Water,.Antifreeze,.Rag1.Use the search,2.Remove the brake pads,3.Add the antifreeze as required,4.Add the water to the bucket,5.Unsrew the tpa all of the way out,6.Unscrew the bolt on the caliper (5mm),7.Pump the lever about 20 times, or until you see no air coming out,8.Tighten the bolt up,9.Undo the 3mm bolt on the lever,10.Pump the lever another 20 times,11.Screw the bolt back in,12.Dry the brake off,13.Pump the lever a few times to get it going,14.Put the pads on the magura15.Fit to the bike16.Ride17.Thank me very much for spending my time helping you Lol... Edited February 5, 2007 by monty ryder Quote Link to comment Share on other sites More sharing options...
adam trials Posted February 5, 2007 Report Share Posted February 5, 2007 Well i can tell you one method but t would be easier if you used the search.You will need: one clean washing up liquid bottle, or a syringe, old magura hose if possible and your buckets. With the top of the washing up liquid bottle you make the hole slightly bigger to fit the part of the hose in.Fill the bottle with water and anti-freeze.You then need to take off both bolts and pump the contents of the washing up liqiud bottle through the magura untill there is only water and the anti-freeze coming out. You then need to make sure both sides are completly submerged untill you fasten the bolts back in. Your brakes should then be fine.If this does not work then use th search and see what other people have said.Adam. Quote Link to comment Share on other sites More sharing options...
t-liteboy Posted February 5, 2007 Author Report Share Posted February 5, 2007 Well i can tell you one method but t would be easier if you used the search.You will need: one clean washing up liquid bottle, or a syringe, old magura hose if possible and your buckets. With the top of the washing up liquid bottle you make the hole slightly bigger to fit the part of the hose in.Fill the bottle with water and anti-freeze.You then need to take off both bolts and pump the contents of the washing up liqiud bottle through the magura untill there is only water and the anti-freeze coming out. You then need to make sure both sides are completly submerged untill you fasten the bolts back in. Your brakes should then be fine.If this does not work then use th search and see what other people have said.Adam.ok mate thankscheersjake Quote Link to comment Share on other sites More sharing options...
adam trials Posted February 5, 2007 Report Share Posted February 5, 2007 Its alright dud dont worry about it. Im happy to help if it gets you out on your bike again. In future could you please use the search before posting topics like this though.Adam. Quote Link to comment Share on other sites More sharing options...
t-liteboy Posted February 5, 2007 Author Report Share Posted February 5, 2007 Its alright dud dont worry about it. Im happy to help if it gets you out on your bike again. In future could you please use the search before posting topics like this though.Adam.ok mate will do! Quote Link to comment Share on other sites More sharing options...
adam trials Posted February 5, 2007 Report Share Posted February 5, 2007 When are you bleeding them i would recomed A.S.A.P because you may find some methods easier than others. Try out different ways and see what you find easiest. I find the way i posted but a few people i know find other ways easier and quicker.Adam. Quote Link to comment Share on other sites More sharing options...
onzat-comp Posted February 5, 2007 Report Share Posted February 5, 2007 HiI hate to be a drag but I'm sure there was a topic like this the other day not getting on at you but please search before you post.Thanks Rick Quote Link to comment Share on other sites More sharing options...
adam trials Posted February 5, 2007 Report Share Posted February 5, 2007 HiI hate to be a drag but I'm sure there was a topic like this the other day not getting on at you but please search before you post.Thanks RickWe alredy told him lol but may aswell help out too lolAdam. Quote Link to comment Share on other sites More sharing options...
ted Posted February 5, 2007 Report Share Posted February 5, 2007 (edited) HiI hate to be a drag but I'm sure there was a topic like this the other day not getting on at you but please search before you post.Thanks RickHeres one. Edited February 5, 2007 by ted Quote Link to comment Share on other sites More sharing options...
t-liteboy Posted February 5, 2007 Author Report Share Posted February 5, 2007 any one als Quote Link to comment Share on other sites More sharing options...
