Titanium Frame
ZHI_Chris
The frame are the only three production.
The titanium factory accept designated by yourself. Even if only one frame.
looks perfect, how much did it cost him with it being titanium and all lol
what tensioner is he running never seen one like it before, sprung?
Steve
the tensioner was make by himself. Very light!
will the brake mounts being on the underneath not make it have less breaking power??
Because it will be pulling away from the frame.
the brake being on the underneath make a strong power.
because push power is bigger then pull power.
Effectively prevent the wheels reverse turning.
Edited by zhi
Well how cum the koxx forks with reverse mounts work seem to have more power than standered forks, and with them it is pushing into the frame, unlike the rear mounts on this bike ?
because when you use the koxx forks, you use them travelling forwards, hence the better braking performance, the same way a normal maggie on the top at the rear would when the wheel is traveling into the frame, but on gaps and taps etc you want the brake to work backwards better, so it holds.
