STC Posted February 4, 2007 Report Share Posted February 4, 2007 Read Topic DescrptionHow do I get a new star nut inside the forks or spider what ever they are called clips,pics will doCheers,Luke Quote Link to comment Share on other sites More sharing options...
Synergy Posted February 4, 2007 Report Share Posted February 4, 2007 Read Topic DescrptionHow do I get a new star nut inside the forks or spider what ever they are called clips,pics will doCheers,Luke]quite easily hammer it in lol just make sure its in straight or take it to your local bike store and get them to do it for you Quote Link to comment Share on other sites More sharing options...
adam trials Posted February 4, 2007 Report Share Posted February 4, 2007 I used an old screw driver to keep it straigt and hammered it until it didnt mave.Adam. Quote Link to comment Share on other sites More sharing options...
flas12345 Posted February 4, 2007 Report Share Posted February 4, 2007 i had a problem like this on the first day i got my trials bike, but all i did was got a mallet and a piece of copper pipe and tapped it down the forks making sure that it went it straight. i tapped it down further than i actually needed it then i put the pipe in the forks from the bottom and tapped it back up to where i neded it, this way it helps the star nut to grip to the forks. since i did this i have not had another problem with it yet.hope i have helped you.cheers louis. Quote Link to comment Share on other sites More sharing options...
STC Posted February 4, 2007 Author Report Share Posted February 4, 2007 i had a problem like this on the first day i got my trials bike, but all i did was got a mallet and a piece of copper pipe and tapped it down the forks making sure that it went it straight. i tapped it down further than i actually needed it then i put the pipe in the forks from the bottom and tapped it back up to where i neded it, this way it helps the star nut to grip to the forks. since i did this i have not had another problem with it yet.hope i have helped you.cheers louis.Cheers mate, i will give that ago lol Quote Link to comment Share on other sites More sharing options...
core Posted February 4, 2007 Report Share Posted February 4, 2007 i would deffinetly recomend taking it to your local bike shop if you dont have the propper tools but thread a bolt in there and tap away with a rubber mallet if you have no time Quote Link to comment Share on other sites More sharing options...
Andeee Posted February 4, 2007 Report Share Posted February 4, 2007 Read Topic DescrptionHow do I get a new star nut inside the forks or spider what ever they are called clips,pics will doCheers,Lukei told you on msn how to get it out and to get it in you oviously use reverse psycology. * SPAZ* Andy Quote Link to comment Share on other sites More sharing options...
Simpson Posted February 4, 2007 Report Share Posted February 4, 2007 you dont have the propper toolsBitta wood and a hammer =Djob doon Quote Link to comment Share on other sites More sharing options...
Si-man Posted February 4, 2007 Report Share Posted February 4, 2007 Just use the bolt that comes with the topcap.Screw it in abit, tap it down with that.Jobs a goodun Quote Link to comment Share on other sites More sharing options...
CurtisRider Posted February 4, 2007 Report Share Posted February 4, 2007 Just use the bolt that comes with the topcap.Screw it in abit, tap it down with that.Jobs a goodunayyyye hes got it thimple! Quote Link to comment Share on other sites More sharing options...
Dan6061 Posted February 5, 2007 Report Share Posted February 5, 2007 Tap it in with the bolt, then to get it sitting straight in the steerur tube, get a socket that fits (near enough) perfectly in the steerur, and put that over the star nut, and tap that down. Quote Link to comment Share on other sites More sharing options...
python_man Posted February 5, 2007 Report Share Posted February 5, 2007 dont tap it whack it Quote Link to comment Share on other sites More sharing options...
