Fileing My Frame
newb
Hi
ive got a cassete hub alrealdy on mi bmx but i dont ride it much any more so i want to put the hub on my trials bike but it is 14mm and the dropouts are 14mm will it weaken my frame alot if i file the dropouts out abit so it would fit
should i do it ?
help would be great
Adam, :mellow:
ok ,thanks
if you're set on running the bmx hub you could just grind a couple mm off the axle on each side - so you'd get a flat bit that fits your dropouts and still have thread all the rest of the way round. I reckon that'd be alright and if you f**k it up it's only an axle rather than a frame
i take it you've counted the spoke holes(ie. its not a 48 spoke hub)
