_Owen. Posted February 4, 2007 Report Share Posted February 4, 2007 (edited) im part way through saving for my new frame, and wondering if i buy a 19" rear now to fit to my new frame will it fit by t-vee frame that i am using at the moment. basically will a 19" rear fit a t-vee? has any one done it or known anyone that has done it? sorry if this is a repost, but i did a search and nothing was returned. any help will be greatly appreciated. thanks owen Edited February 4, 2007 by owentrialsman Quote Link to comment Share on other sites More sharing options...
clarkytrials Posted February 4, 2007 Report Share Posted February 4, 2007 (edited) I tride the same thing and it will not work but like u sed you are gettin a new frame so you mite need one for that Edited February 4, 2007 by clarkytrials Quote Link to comment Share on other sites More sharing options...
adam trials Posted February 4, 2007 Report Share Posted February 4, 2007 It would probably not work because of the braks but why not try it?See if it works, if not use a 20".Adam. Quote Link to comment Share on other sites More sharing options...
CJtrials Posted February 4, 2007 Report Share Posted February 4, 2007 Hi mate,no it doesn't work as I tried it when I had mine and it was impossible because of the V brakes.CJ.. Quote Link to comment Share on other sites More sharing options...
_Owen. Posted February 4, 2007 Author Report Share Posted February 4, 2007 thanks for all the fast replys. i had the crazy idea that if i filed away at the little gap where you put the axle through the frame then you may be able to move the wheel forward far enough to make the brakes line up. was i wrong do you think. Quote Link to comment Share on other sites More sharing options...
CurtisRider Posted February 4, 2007 Report Share Posted February 4, 2007 thanks for all the fast replys. i had the crazy idea that if i filed away at the little gap where you put the axle through the frame then you may be able to move the wheel forward far enough to make the brakes line up. was i wrong do you think.thats exactly how to do it, and it works, making the dropout slot longer means the wheel can tuck in more, thus lining it up with the brake mountsat least somebody isn't stupid Quote Link to comment Share on other sites More sharing options...
tom 20 Posted February 4, 2007 Report Share Posted February 4, 2007 It will only work if your using hs33 brakes Quote Link to comment Share on other sites More sharing options...
CurtisRider Posted February 4, 2007 Report Share Posted February 4, 2007 It will only work if your using hs33 brakes it'll work with v brakes too if you extend the dropout slot Quote Link to comment Share on other sites More sharing options...
tom 20 Posted February 4, 2007 Report Share Posted February 4, 2007 ye but i was saying that because it would need much modification Quote Link to comment Share on other sites More sharing options...
Dan6061 Posted February 4, 2007 Report Share Posted February 4, 2007 Cheaper to file it though.. Only problem with filing it, is chain tension... Quote Link to comment Share on other sites More sharing options...
bionicman Posted February 5, 2007 Report Share Posted February 5, 2007 19" wheel and a maggie and it works Quote Link to comment Share on other sites More sharing options...
_Owen. Posted February 5, 2007 Author Report Share Posted February 5, 2007 (edited) iv got a magura but i hate it so i put my vee back on and dont intend on going back. by the look of it my vee had alot of adjustment left (if you get me). has anyone put a 19" on with a vee?? o ye thanks for your help again Edited February 5, 2007 by owentrialsman Quote Link to comment Share on other sites More sharing options...
tryalltom Posted February 5, 2007 Report Share Posted February 5, 2007 it did not work with me .i was well p***ed off an just paid good money for that and it did not fit Quote Link to comment Share on other sites More sharing options...
_Owen. Posted February 5, 2007 Author Report Share Posted February 5, 2007 haha. were you using a vee mate?? Quote Link to comment Share on other sites More sharing options...
CurtisRider Posted February 5, 2007 Report Share Posted February 5, 2007 i did it with a v, just go get a new wheel, and a file and bloody do it Quote Link to comment Share on other sites More sharing options...
t-liteboy Posted February 5, 2007 Report Share Posted February 5, 2007 hi mate i think it will because my mate had just a 20'' frame but he put a 19'' on it and he ran a vee brake and all he to do was move the pads right down, then he put a maggy on and just moved thatright down so hope this helps.cheersjake Quote Link to comment Share on other sites More sharing options...
