baz123 Posted February 4, 2007 Report Share Posted February 4, 2007 hi,ive just got a kooka disk brake for nothing, but the thing is it desperatley needs a bleed and i havent got the slightest idea how to bleed it.i got itoff a mate and he sed i can have it but i got to get it working. its probaly rubbish but i got it for free so its worth a try surely.thanks for your time. baz, Quote Link to comment Share on other sites More sharing options...
teeth Posted February 4, 2007 Report Share Posted February 4, 2007 use the search tool maybe?? Quote Link to comment Share on other sites More sharing options...
fruitbat Posted February 4, 2007 Report Share Posted February 4, 2007 Or take it to a bike shop and get a proper job done, saves you doing it and making a bad job of itFrooty Quote Link to comment Share on other sites More sharing options...
Krisboats Posted February 4, 2007 Report Share Posted February 4, 2007 Do a quick bleed. Take the resevoir cap off, pull the lever repeatedly while flicking the cable and wait for the air bubbles to stop rising. Whack the cap back on and see how it feels. Quote Link to comment Share on other sites More sharing options...
flas12345 Posted February 4, 2007 Report Share Posted February 4, 2007 hi mate.i had two hope disk brakes and they needed a bleed once and this is how i did it,take the top cap off near the leverinscrew the bolt that is in the caliperfill a seringe up with which ever oil the brake takes(in my case it was dot 5)insert the seringe into the caliperinsert all the oil into the caliper and whilst doing this pump the leverthen when all oil is through the brake and there are no bubbles put top cap back on and screw bolt back into the caliperhope i have helped you mate and good look with your brake. Quote Link to comment Share on other sites More sharing options...
