Pads Stick To My Rims
dan the trials man
you use tar?
if not, is your magura at an angle/pad worn funny (my pads wore wierd + got pinched between rim/tyre before) could be at an angle spinning the pad into the rim (can't explain it to well though :S ) doubt it'd be that though
could be, homework for tonight then would be:
take of maguras (only slaves not lever)
max out your tpa
zip tie lever down as close as it'll go to the bars (making the piston poke out)
push one piston in (so the other one comes out more)
spray in WD40 (or similar) wipe of any crap
do the same to other caliper
repeat if theres still any crap
bleed if you feel like it (Y)
set up maguras again
grin like a gay when it work/cry when it hasn't woked
have fun (Y)
