Maxxis Creepy Crawler Problem
jsychem
Hi, I've had some problems with my Creepy Crawler. About 2 weeks ago i had a puncture and took off my rear creepy crawler. When i put it back on the tyre wall kept on coming off the rim and i was running on about 18 PSI. I am also using Echo Rims and simply do not understand why this happens. Does any one have any reasoning for this?
Got the same problem there mate ive got a bulge in my tire so everytime i change the innertube pr somethin or when im ridin the tire is part was of the rim( im running a echo rim aswell) could it be the rim is yours 06 or a 07 rim?
I run a echo front 07 rim and creepy crawlers,
Try and get someone to help you with this.
1) Take your wheel off
2) Let down tire
3) Pump up and see which bit it "popping" out
4) Let down again
5) Hold bit which is "popping out" (get someone to do this)
6) Pump back up
7) It should of hopefully worked (if not repeat)
8) Fit wheel.
Hope this helps.
Lewis (Y)
Thanks for the reply, i am running an 06 on the back and 07 on the front. What about you? and thanks for all the other help guys, will try that!!!! :)
Edited by jsychem
Hi there,what you have to do is when you pump your tyre up,look at the bead of the tyre all way round and push it against the rim,it is like a motorcross tyre,because the tyre is bigger than the rim,when you pump up the tyre it expands and the bead of the tyre sits on the inside of the rim.thanks shane.
