Crank Set
Netherking
hey
i need some advice with a crank set, mines shit at the moment, onza crank, crapy bent bashring,which has bent the sprocket and forcing it into the frame!!!
so i'm gonna get some new stuff, not much cash 75-80 no more,
i think i'm gonna try 18tooth on the front, i found a few things on tarty what do you think:
http://www.tartybikes.co.uk/product.php?id=156
http://www.tartybikes.co.uk/product.php?id=179
http://www.tartybikes.co.uk/product.php?id=32
will these all work together, i'm running rear freewheel, and a square tapered BB,
and does the bashring just clamp in between the sprocket? does it need a lock nut on the othr end?
Btw all to go on a T-tex
thanks very much,
harry
Good reliable parts you're looking at there, can't fault any of them really! As long as all threads/tapers are kept tight (including checking for the first few riders) they'll last ages.
The bashring is held on by the screw-on sprocket, yes. If you go ahead, make sure you fit the sprocket with grease or anti-sieze - will make it much easier to get off in future!
Cheers
Adam
Cheers
Adam
sweet cheers
and do you need a lock nut on the other size of the sprocket? closest the BB,
i will go ahead, its been taking the piss really had so many problems!
Make sure its reasonably tight before you do any gapping from the back wheel. I tried with jonnys and was suprised by just how much further it kept tightening as i tried to gap... kind of gave the same effect as the chain snapping.
Sit with the brake nearly fully on and try and pedal around, then do little gaps to tighten it properly.
cheers i'll remember that
i just tried to order but is wasn't processing is tarty bikes down?
