Blommah Posted January 31, 2007 Report Share Posted January 31, 2007 (edited) As i`m putting my new Gu 26" together, i found that i couldnt use my monty pads.I had to swith to my green magurapads, as the montypads are wider, so that my hs33 keeps touching my crankarms when they spin, the brake goes too far out.A common problem with trialsframes nowadays?Advice? I guess i have to live with it, or just cut the pads, but i rather wouldnt. Edited January 31, 2007 by Blommah Quote Link to comment Share on other sites More sharing options...
Lawnmowerman Posted January 31, 2007 Report Share Posted January 31, 2007 Get a wider bb. Quote Link to comment Share on other sites More sharing options...
Blommah Posted January 31, 2007 Author Report Share Posted January 31, 2007 I thought of that, but on the other hand, dont it affect the chainline? Quote Link to comment Share on other sites More sharing options...
Lawnmowerman Posted January 31, 2007 Report Share Posted January 31, 2007 Better to have a slightly bent chainline than your crank hitting your brake. Quote Link to comment Share on other sites More sharing options...
Ash-Kennard Posted January 31, 2007 Report Share Posted January 31, 2007 Better to have a slightly bent chainline than your crank hitting your brake.hes right Quote Link to comment Share on other sites More sharing options...
Blommah Posted January 31, 2007 Author Report Share Posted January 31, 2007 hes rightYeah, thats right, but i got it sorted with the other pads, dont really wanna buy a new bb, cheaper with other pads Quote Link to comment Share on other sites More sharing options...
Onza Kieron Posted January 31, 2007 Report Share Posted January 31, 2007 Well then cut the pads down, or buy the echo brake.. Quote Link to comment Share on other sites More sharing options...
Dan6061 Posted January 31, 2007 Report Share Posted January 31, 2007 Well then cut the pads down, or buy the echo brake..or...get a wider BB. Quote Link to comment Share on other sites More sharing options...
abtrials Posted February 1, 2007 Report Share Posted February 1, 2007 or you could get a thiner rear rim, or swap your cranks for some 5mm smaller Quote Link to comment Share on other sites More sharing options...
GTF Posted February 1, 2007 Report Share Posted February 1, 2007 I thought of that, but on the other hand, dont it affect the chainline?You can change the position of the cog? Quote Link to comment Share on other sites More sharing options...
Lawnmowerman Posted February 1, 2007 Report Share Posted February 1, 2007 Or if you really have to you can take your pedal off, put a long pole over the crank and bend the arm outwards slightly. It's not very professional but it does work. Quote Link to comment Share on other sites More sharing options...
Blommah Posted February 1, 2007 Author Report Share Posted February 1, 2007 You can change the position of the cog?Well the tensioner is homemade so it really dont adjust that well, ill stick with the smaller pads . Quote Link to comment Share on other sites More sharing options...
darrenhopper Posted February 1, 2007 Report Share Posted February 1, 2007 Give the new pads to a mate who runs a grind for a couple of sessions? They'll probably fit just fine if you leave them long enough & somebody gets to knock a bit of use out of them... Gots to be better than cutting them down, getting an un-even surface & you'll always resent the fact that you lost out on those 2 mm of material when it's time for new pads. Quote Link to comment Share on other sites More sharing options...
Greetings Posted February 1, 2007 Report Share Posted February 1, 2007 I had to grind down my cranks, magura caliper, brake pads and get a narrower rim. Setup is an A1 with 128mm bb, Tensiles and Coustsinks. What's the widest 68mm shell bb one can get? Quote Link to comment Share on other sites More sharing options...
James Quigley Posted February 1, 2007 Report Share Posted February 1, 2007 I had this problem with my GU, with a 127.5mm BB.I solved it by buying new cranks.My middleburn 175's hit the cylinderMy new Try All 175's miss by at least 1 mile.Problem solved Quote Link to comment Share on other sites More sharing options...
