teeth Posted January 31, 2007 Report Share Posted January 31, 2007 Hi i know this is trials forum but what psi does anybody run on there bmx? need help please im 6 ft and 10 1\2 stone i think that right thanks for any help teeth Quote Link to comment Share on other sites More sharing options...
mbuk Posted January 31, 2007 Report Share Posted January 31, 2007 Hi there mate,on my fly,i run odyssey path tires i run 110psi,im 6.2 and 14 stone,[not fat].Hope i have helped. Quote Link to comment Share on other sites More sharing options...
liam_thornton Posted January 31, 2007 Report Share Posted January 31, 2007 When I used to do bmxing i ran 60-70psi, i'm about 5.7ft and about 8.5 stone. Quote Link to comment Share on other sites More sharing options...
CurtisRider Posted January 31, 2007 Report Share Posted January 31, 2007 55 rear, 65 front seems to do me well, i'm 13 stone and 6ft2 and mainly do street Quote Link to comment Share on other sites More sharing options...
Jed Posted January 31, 2007 Report Share Posted January 31, 2007 Around 50 psi on each tire for me i'm 5ft 10" and weigh 9 1/2 stone and mainly do park.Jed. Quote Link to comment Share on other sites More sharing options...
core Posted January 31, 2007 Report Share Posted January 31, 2007 im like 10 stone 5' 8 ish and i run 90 on both Quote Link to comment Share on other sites More sharing options...
Hendrix Posted January 31, 2007 Report Share Posted January 31, 2007 (edited) See.I just go, is it hard, yes ? Good.I have a little bit of give in the back and front, but it's basicly solid... MAYBE not a good tecnique ? Edited January 31, 2007 by Hendrixmaster Quote Link to comment Share on other sites More sharing options...
Tailz222 Posted February 1, 2007 Report Share Posted February 1, 2007 Hi i know this is trials forum but what psi does anybody run on there bmx? need help please im 6 ft and 10 1\2 stone i think that right thanks for any help teethHey dude, well it depends on what you ride, dirt, park, street? i ride dirt as well as trials and i ride at 100psi but my mates ride park and they run 60psi. all depends on what u ride. Quote Link to comment Share on other sites More sharing options...
BONGO Posted February 1, 2007 Report Share Posted February 1, 2007 Hey dude, well it depends on what you ride, dirt, park, street? i ride dirt as well as trials and i ride at 100psi but my mates ride park and they run 60psi. all depends on what u ride. thats totally backwards! you need higher pressures on ramps becasue of the forces when you land into a rmap squashing the tyres. You lose all your pump on a ramp if you're tyres aren't really hard.first of all though, don't exceed what your tyres recommend. Pretty safe bet though, if you're riding park, you would do good filling the tyres to their max psi rating. ( it's stated on the tyre)I run 100psi too. Quote Link to comment Share on other sites More sharing options...
Tailz222 Posted February 1, 2007 Report Share Posted February 1, 2007 (edited) thats totally backwards! you need higher pressures on ramps becasue of the forces when you land into a rmap squashing the tyres. You lose all your pump on a ramp if you're tyres aren't really hard.first of all though, don't exceed what your tyres recommend. Pretty safe bet though, if you're riding park, you would do good filling the tyres to their max psi rating. ( it's stated on the tyre)I run 100psi too.I do trails riding and i run at 100psi and my mate rides park and he runs 60psi, for dirt you need high psi to keep up the speed for the next jump, park you dont need it so hard cause you dont need to keep up loads of speed unless you run halfpipes but still 100psi for park is bit hard. Edited February 1, 2007 by Tailz222 Quote Link to comment Share on other sites More sharing options...
BONGO Posted February 1, 2007 Report Share Posted February 1, 2007 I do trails riding and i run at 100psi and my mate rides park and he runs 60psi, for dirt you need high psi to keep up the speed for the next jump, park you dont need it so hard cause you dont need to keep up loads of speed unless you run halfpipes but still 100psi for park is bit hard.If you wanna keep your speed in a park of course you need hard tyres!! it's the best feeling in the world pumping ramps until you want to stop with not a single pedal. You can't d that without hard tyres. Apart from flowing ramps and pumping (exactly the same reasons as trails), soft tyres in a park can be dangerous. i've been out cold when i pmped a bowl corner heading towards a curved wallride when my below pressure tyre squashed right in and squirmed from my rim, sending me to the ground on my head. 60 ain't that low depending on the tyre and the rider weight, but it's certainly a lot lower than i'd like. Park requires high PSI. Quote Link to comment Share on other sites More sharing options...
teeth Posted February 1, 2007 Author Report Share Posted February 1, 2007 ok thanks for all the info guys and girls. but now i need to know what would be the best bmx for street & park for about 200-300 300 being the most? cheers teeth Quote Link to comment Share on other sites More sharing options...
Tailz222 Posted February 1, 2007 Report Share Posted February 1, 2007 ok thanks for all the info guys and girls. but now i need to know what would be the best bmx for street & park for about 200-300 300 being the most? cheers teeth Soz dude cant help you there, i only know about trails bmx's. Quote Link to comment Share on other sites More sharing options...
