Chain Skipping
Trials Dave
ok, a while a go i bought a kmc kool chain and fitted it to my zoo pitbull.it was jumping like mad every few pedal strokes so i spaced out my mech and tried the sprocket in different plaaces on cassette to check the chain alignment was alright. but still didnt fix the problem!!
so i bought a surly rear splined sprocket and it was fine for a while then it starting skipping again!!
so i bought a khe collapse chain and a new surly rear sprocket! still no better!! i have set my mech up perfectly in line etc and it is single speed on a chris king hub, my mech is spaced out, chain alignment is good, i dont have a stiff link!!!, chain is nice and tight and i am really baffled about it!!
any ideas people??
thank you
Change your front cog.
As he said.
Chains, cogs, and sprockets all wear evenly.
Really, you should replace them all at the same time when they wear out, as replacing say, just the chain, and leaving the cogs etc, then the chain will just wear down so it'll run with everything else.
If you replace them all at the same time, it'll last much longer.
Even though it means breaking the bank some more. ;)
As he said.
I agree its a mismatch of pitches between the old sprockets and the fresh new chain. Out of pitch means it'll skip or run through under load.
Theres no need to replace all at once though. You should be able to get about 3 chains per sprocket set, just replace them at regular intervals (before they wear too much and then you're up for a new set). Either get a chain wear indicator tool or take your bike into your LBS and they'll measure it for you. Generally they'll do this for nothing since its potentially a purchase of a new chain.
well i'll wack a new front sprocket on and see what happens!.
cheers. mite get a single speed tensioner aswell instead of my mech.
craig did you have a similar problem when you put your wide kmc on a while ago? whenever you put a few pedal strokes in it skipped????
My Dad knows how to avoid this, because he rides XC, he says to start with a new set of sprockets and THREE new chains, once the chain gets worn slightly, put on a new one, then run that one the same, and the next. Then put the origenal one back on. You should be able to run all three chains three times, in the end you are left with a complete set of knackered stuff, but no chain suck, ghost shifting or anything. AND he could get a good couple of thousand miles out of the set, then he would just buy new all new kit and start again.
It worked for him but I don't know about trials bikes, I tend to get about 2weeks riding before something goes wrong and it needs new bits.
