Need Some Help
george_seamons
Thanks to a new frame, I need some help with some 4 bolt adaptors I'm going to have to make.
I need to know the thread size of the bolt that vee brake mounts screw into. Not the thread of the bolt, I know that's M5. But the one of the actual boss. Apparently Bigman knows, so hopefully somebody else will see this topic that also knows.
Thankings
The boss thread size is M10 x 1.25 which is a b*****d of a size as it is not a very common size, fortunatly my grandad has most things so i was able to get it.
If you get stuck i have some home made ones here i would lend you to get you going.......
Adam
