jonny_smith Posted January 29, 2007 Report Share Posted January 29, 2007 hey,After sorting out my front maggie (works real nice now) i have been thinking of the advantages of putting an Avid BB7 on the front (203mm) (would put a Hope on but cannot afford it and i have heard good things about this brake) and running a echo front hub ( i like the idea of the allen bolts becuase i've already messed up my QR quite a bit on my deore) but my question to you lot is what lever and cable would you recommend? I have a shimano deore V-Brake lever and cable (brand new) hanging about would this work nice or would you recomend something else? I want the brake to feel very solid because i hate squishy feeling brakes.Thanks for the adviceJonny Quote Link to comment Share on other sites More sharing options...
Deano_1 Posted January 29, 2007 Report Share Posted January 29, 2007 hey,After sorting out my front maggie (works real nice now) i have been thinking of the advantages of putting an Avid BB7 on the front (203mm) (would put a Hope on but cannot afford it and i have heard good things about this brake) and running a echo front hub ( i like the idea of the allen bolts becuase i've already messed up my QR quite a bit on my deore) but my question to you lot is what lever and cable would you recommend? I have a shimano deore V-Brake lever and cable (brand new) hanging about would this work nice or would you recomend something else? I want the brake to feel very solid because i hate squishy feeling brakes.Thanks for the adviceJonny first of all id like to say the avid BB7 is a brilliant brake my brother has just got one with this lever. http://www.chainreactioncycles.com/Models.aspx?ModelID=6198there very nice levers as the blade is quite like the old maggies and not to pricey. anyway hope that helps Quote Link to comment Share on other sites More sharing options...
bionicman Posted January 30, 2007 Report Share Posted January 30, 2007 i use an avid bb7 with a bmx cable with some crappy ador lever ive never heard of its got a smooth and solid pullalso before fitting it spray wd40 down the cable this helps it to slide easier Quote Link to comment Share on other sites More sharing options...
laurent Posted January 30, 2007 Report Share Posted January 30, 2007 It's a quite simple.Try to use bb7 with your shimano deore V-Brake lever ....and if it doesn't work...buy avid fr5, sd 7 or xtr lever for example.But it'll probably works fine because avid bb7 is a greatest brake...maybe THE best. Quote Link to comment Share on other sites More sharing options...
Dan6061 Posted January 30, 2007 Report Share Posted January 30, 2007 BB7 - £53.99XTR Lever - £29.99Odyssey Linear Slic Cable - £6.00Total: £89.98Mint brake. Quote Link to comment Share on other sites More sharing options...
chris mac Posted January 30, 2007 Report Share Posted January 30, 2007 bb7 + mountain bike outer and inner + xtr lever had it on the front of my bighit at one point was the best brake ever beats hope m4s and so on, and becasue they are cable they dont leak so you dont thave to faff around with seals and bleeding and so on. Quote Link to comment Share on other sites More sharing options...
jonny_smith Posted January 30, 2007 Author Report Share Posted January 30, 2007 awesome cheers folks you've pursuaded me will get hub 1st nxt months and then brake month after because i get paid monthly and have a car to run Quote Link to comment Share on other sites More sharing options...
