Captain Scarlet Posted January 26, 2007 Report Share Posted January 26, 2007 Okay something that I am considering for the future is to switch to a front freewheel on my Onza T-Vee, maybe not anytime soon but I want to work out a cost effective method of doing it. Perhaps when If I get a new frame for christmas I could, as its a good excuse to change my cranks because the T-bird cranks would look horrible.Anyways, at the moment I have an Onza T-Vee (07), it has the standard square taper T-Bird cranks, but I want to know if I can put my standard rear Dicta 18T freewheel on the front, then change the rear hub to one that has a sprocket. Would I be able to do this.I mean I think I'll change the cranks sometime anyways, because the Onza ones look crap imo, but I want to know if I can change to a front freewheel without my pants being pulled down over the price.Thanks, Tom Quote Link to comment Share on other sites More sharing options...
Dan6061 Posted January 26, 2007 Report Share Posted January 26, 2007 I wouldn't advise using a Dicta freewheel on the front, as it would come loose all the time, and they're just not good. Get a Tensile freewheel, enough engagments, around £30 aswell I think. Then have a look about for some 2nd hand front-freewheel cranks.Or get some new, Echo 6061 crankls for £52...Then you'd need a 12t fixed cog on the back, they're about £10.With all that, it'd be £92 at the most.If you can get some 2nd hand stuff, I guess it'd be around £50 maximum. Quote Link to comment Share on other sites More sharing options...
Captain Scarlet Posted January 26, 2007 Author Report Share Posted January 26, 2007 (edited) Hmn, thanks for the input Dan.So I take it that the standard cranks don't have the front freewheel option, I had my eye on the Echo cranks anyways. To get a fixed cog on the rear, would I need to change my freewheel? or would it just slip on/whatever it does?Thanks,EDIT: *Would I need to change my rear hub* Not freewheel =S Edited January 27, 2007 by thutley Quote Link to comment Share on other sites More sharing options...
Muel Posted January 26, 2007 Report Share Posted January 26, 2007 To be honest you are better of buying a new bike, I you ar going to put all these bt on it...FFW does make a difference to the looks and some to the ride, the chain can be tighter because its closer to the chainstay etc, but I wouldn't do it, Keep the money, sell the T-VEE and but the T-PRO on here for £150, then all you need is a complete rebuild, a new bash plate (Or just ride uci), new brake lever, £15 on here, and your pretty much set.Or save lots of moeny and get a brand new echo team or similar!Ride it as it is, you will find that the geometry and the entire spec will hinder your riding far more than not having a ffw. Quote Link to comment Share on other sites More sharing options...
Captain Scarlet Posted January 27, 2007 Author Report Share Posted January 27, 2007 Hmmn, I guess thats a different input to it.See with my budget and things at the moment I find it much easier to buy bits at a time I mean if I switched to a front freewheel, I can just buy the cranks at first keeping with the freewheel on the back, then when I get more money I buy the new freewheel for the front and rear sprocket.I mean to be honest, not many people are going to want an Onza T-Vee unless it is a starter bike, its just not worth the hassle of selling it to get another Onza.I mean over time, I'd slowly build into a better bike, so its practical for a budget like mine. Quote Link to comment Share on other sites More sharing options...
mods Posted January 27, 2007 Report Share Posted January 27, 2007 No you wouldn't need to change your rear hub as it's a fixed hub anyway. You would have to take off your freewheel which is on the back, put a 12 tooth sproket on there instead. Then buy a ' NEW' freewheel and whatever front freewheel cranks you can get. Quote Link to comment Share on other sites More sharing options...
