MikeCottTrials Posted January 25, 2007 Report Share Posted January 25, 2007 How do you do it? bit of a noob question i know but it has to be done btw Ive already done a search and it didnt really help Quote Link to comment Share on other sites More sharing options...
TheMunn Posted January 25, 2007 Report Share Posted January 25, 2007 Clamp it in a vice as hard as you can, then put a piece of scaffold pole on the crank to undo it. If you don't want to damage the sprocket then put a piece of old chain around it before putting in the vice. Quote Link to comment Share on other sites More sharing options...
abtrials Posted January 25, 2007 Report Share Posted January 25, 2007 (edited) Clamp it in a vice as hard as you can, then put a piece of scaffold pole on the crank to undo it. If you don't want to damage the sprocket then put a piece of old chain around it before putting in the vice.or get 2 x blocks of wood and put them in between the sprocket and the vice, grab hold of the wheel and turn, job done (if you are talking about a rear sprocket) if not above will work Edited January 25, 2007 by rwiley Quote Link to comment Share on other sites More sharing options...
Dan6061 Posted January 25, 2007 Report Share Posted January 25, 2007 Two blocks of wood idea didn't work for me, the cog kept chewing through any wood I tried.I used an old chain, and long pole. Quote Link to comment Share on other sites More sharing options...
RR_Trials Posted March 22, 2007 Report Share Posted March 22, 2007 Just a quick question, is the chain method used to take it off a crank aswell, i have an Echo crank and bashring with fixed cog and i want to take them both off.I wanted to get the same gearing as on my onza so would i be able to take my ordinary T-Bird cog off and put it onto my echo cranks?Cheers in advance, Rorz! Quote Link to comment Share on other sites More sharing options...
kid creole Posted March 22, 2007 Report Share Posted March 22, 2007 yeah , thats what hes talking about. Its just that someone then started talking about wheels for no reason, i got halfords to get mine off and it only cost me £5.00 Quote Link to comment Share on other sites More sharing options...
j-bonham@hotmail.com Posted March 22, 2007 Report Share Posted March 22, 2007 (edited) Clamp it in a vice as hard as you can, then put a piece of scaffold pole on the crank to undo it. If you don't want to damage the sprocket then put a piece of old chain around it before putting in the vice.Is that the same idea to get a screw on bash ring off..... i have tensile cranks with a duel bash. tryed to get it off with a whain whip, but the whip snapped!!vice idea sound good. Edited March 22, 2007 by johny boy Quote Link to comment Share on other sites More sharing options...
