moto_psycho Posted January 24, 2007 Report Share Posted January 24, 2007 Pros and cons?! I have HS33s, but in the future on future bikes I eventually own, would it be worth changing to discs? ive heard they dont snap up as quick as rims..? true? cheers dudes Quote Link to comment Share on other sites More sharing options...
Greetings Posted January 24, 2007 Report Share Posted January 24, 2007 Front or rear? You'll find a lot on rear discs if you hit the search button.A front disc basically gives you more modulation and quiet braking which is the greatest advantage, however Magura's are lighter, more powerful when properly set up and cheaper. Quote Link to comment Share on other sites More sharing options...
ryan360 Posted January 24, 2007 Report Share Posted January 24, 2007 Its best to stay with hs33, disc on the front is alright but on back they can bend easily when your hopping around. Quote Link to comment Share on other sites More sharing options...
JohnyMilton Posted January 24, 2007 Report Share Posted January 24, 2007 hey i ride a Disk up front and its nice its a Avid Juciy 5, then on the rear i ride a avid vbrake, you will find a lot of people run that set up, you should think about giving it ago, its nice to ride!! dont ride a disk on the rear because the mounts could snap easily, it happened to me!!!Johny Quote Link to comment Share on other sites More sharing options...
rolo Posted January 24, 2007 Report Share Posted January 24, 2007 hey guys, im just starting trials and im getting a monty pro with twin disks.is that a bad thing? Quote Link to comment Share on other sites More sharing options...
Broomer Posted January 24, 2007 Report Share Posted January 24, 2007 Its best to stay with hs33, disc on the front is alright but on back they can bend easily when your hopping around.want to explain how? Quote Link to comment Share on other sites More sharing options...
fyfey Posted January 30, 2007 Report Share Posted January 30, 2007 want to explain how?I assume he means by catching it on stuff. Like a derailleur. Probably not that likely, but when you're starting off anything's possible! Quote Link to comment Share on other sites More sharing options...
ben.richardson Posted January 31, 2007 Report Share Posted January 31, 2007 (edited) How can you say that rear disks bend, have you tried one? mines done fine and im a fairly harsh rider.The disk doesn't catch unless e.g you side hop a wall and your front wheel misses the wall and your rear wheel catches your rear disk is then likely to catch which is very rare hasn't happened to me yet. Edited January 31, 2007 by ben.richardson Quote Link to comment Share on other sites More sharing options...
Ghetto Rider Posted January 31, 2007 Report Share Posted January 31, 2007 Alright People,Disc front - low centre of gravity, great bite! and feels / looks awesome!Rim brake back - high centre of gravity, great bite! good for staying on back wheel....- PS - Has anyone used a maggie on back then changed to disc?? easier to balance or harder?? Quote Link to comment Share on other sites More sharing options...
ben.richardson Posted January 31, 2007 Report Share Posted January 31, 2007 I used to ride with a magura on the back ,it takes a bit of time to get used to because you're used to the squeak of the pads hitting the rim and that's when you know the brake has locked on but i wouldn't say it makes it easier to balance Quote Link to comment Share on other sites More sharing options...
Richard jersey Posted January 31, 2007 Report Share Posted January 31, 2007 I have a disc on the front and a HS33 on the back! It works well like that. I don't like having a disc on the back though! If you have the money then i think you should get a disc on the front!Richard Quote Link to comment Share on other sites More sharing options...
ben.richardson Posted January 31, 2007 Report Share Posted January 31, 2007 have you even tried a disk though Quote Link to comment Share on other sites More sharing options...
MattB Posted January 31, 2007 Report Share Posted January 31, 2007 I have used a monty with maggies front and rear and now i use dual disc and i can honestly say the dual disc is 10 time better. I feel like theres more stopping power in the wet and the dry. Gives me more confidence as well. There also less hassle than maguras so if you get the chance to go dual disc i say do it. Matt Quote Link to comment Share on other sites More sharing options...
