ryan360 Posted January 22, 2007 Report Share Posted January 22, 2007 Hi im thinking of getting a freewheel crank but im not sure if you can have a freewheel crank at the front as well as a freewheel hub at the back or do u need to get a fixed hub. Also i was wondering can you still have gears.Thanks ryan Quote Link to comment Share on other sites More sharing options...
gianttrials Posted January 22, 2007 Report Share Posted January 22, 2007 Hi im thinking of getting a freewheel crank but im not sure if you can have a freewheel crank at the front as well as a freewheel hub at the back or do u need to get a fixed hub. Also i was wondering can you still have gears.Thanks ryanNo you need a fixed rear hub, and yes you can run gears, monty and megamo have been using this setup for years,Hope this helps mate,Ben g WST Quote Link to comment Share on other sites More sharing options...
