thaoriginalgangsta Posted January 20, 2007 Report Share Posted January 20, 2007 As seen as i cant write in trials chat ill write here,I was reading about the tesioner earlier today and then i was reading this The tensioner would fit mod, but due to weeny sprocket use it'd be a logistically piece of magic to get everything in to such a small gap (between top and bottom chains) and running smooth with no tensioner modifications.So people are wondering if the tensioner could be run in a mod what Dave@Tartybikes said would be true BUT! what if you were to run say an extra 3 links? in your chain shurly it would run fine?just a thoughtcheers adam Quote Link to comment Share on other sites More sharing options...
Greetings Posted January 20, 2007 Report Share Posted January 20, 2007 Add 3 links to a chain and it'll be hanging right down to the ground. You'd probably set it up with a single halflink on a 18:12 ratio or by running a different gear ratio and longer/shorter chain.Of course you could run a tensioner like that, I guess what Dave had in mind was that it's not worth the hassle. Quote Link to comment Share on other sites More sharing options...
Shaun H Posted January 21, 2007 Report Share Posted January 21, 2007 Yeah, you could just tension your chain like the rest of the world's mod riders? Quote Link to comment Share on other sites More sharing options...
Wright Pads Posted January 21, 2007 Report Share Posted January 21, 2007 Less to worng, not costly when you will defo twat it....just go with the flow of current setup Quote Link to comment Share on other sites More sharing options...
tom 20 Posted January 21, 2007 Report Share Posted January 21, 2007 Less to worng, not costly when you will defo twat it....just go with the flow of current setupwell said . its just something else to break i suppose Quote Link to comment Share on other sites More sharing options...
