nickinator12 Posted January 20, 2007 Report Share Posted January 20, 2007 (edited) basically im getting some parts for my bike and i need to know what is a better tyre out of a creepy crawler, stiky or a eagle claw and i will also get a new bb and cranks but am unsure what axle size ill need 122.5mm or 127.5mm and what is a good crank length 160mm,165mm,170mm or 175mm and i ride an 06 t -pro. Edited January 20, 2007 by nickinator12 Quote Link to comment Share on other sites More sharing options...
Fixed Pants™ Posted January 20, 2007 Report Share Posted January 20, 2007 Maxxis Creepy Crawler. Quote Link to comment Share on other sites More sharing options...
GTF Posted January 20, 2007 Report Share Posted January 20, 2007 Echo tyres. Not sure about the rest, as that's mod stuff Quote Link to comment Share on other sites More sharing options...
Fixed Pants™ Posted January 20, 2007 Report Share Posted January 20, 2007 (edited) Take your cranks off and put a metal ruler through the frame and measure the length of the BB, end to end...And i thought you had to get a certain size for a certain size wheel (crank length) Edited January 20, 2007 by Fat Pants Quote Link to comment Share on other sites More sharing options...
joewhite Posted January 20, 2007 Report Share Posted January 20, 2007 if your running front freewheel you need a longer BB Quote Link to comment Share on other sites More sharing options...
Joe_Elding Posted January 20, 2007 Report Share Posted January 20, 2007 Imo monty tyres are the best available atm... Quote Link to comment Share on other sites More sharing options...
Guest Posted January 20, 2007 Report Share Posted January 20, 2007 Imo monty tyres are the best available atm... Quote Link to comment Share on other sites More sharing options...
Has anyone seen my shoe? Posted January 20, 2007 Report Share Posted January 20, 2007 (edited) Me: Any reason to deviate from cc? JT: noJT: unless your a homosexual Edited January 20, 2007 by Has anyone seen my shoe? Quote Link to comment Share on other sites More sharing options...
RobinJI Posted January 20, 2007 Report Share Posted January 20, 2007 If you're over about 5'8" then I'd go with 165s and if you're shorter then 160s. As for the BB, I think quite a lot of people get away with 122mm axles, but it kinda depends what freewheel and BB you're using.Will the Monty tyre fit in a T-pro? Quote Link to comment Share on other sites More sharing options...
Ash-Kennard Posted January 20, 2007 Report Share Posted January 20, 2007 try-alls are the best/grippyest and you will never puncture them, but wear out too quickly and are stupidly expensivemontys are not as grippy, but still stick to everything and are lighter, im not too sure on pinch protection, bit cheaper toomaxxis creepy crawlers are the worst of them, but are the cheapest and still offer good grip and pinch protection, but are heavytake this: cheap, light, strong pick two Quote Link to comment Share on other sites More sharing options...
Mat Smith! Posted January 20, 2007 Report Share Posted January 20, 2007 Crawler for front, Try-All Monty Echo for rear.Echo probs lasting longest, most bounce, least grip?Monty in the middleTry all, best all around but runs out quick.Mat Quote Link to comment Share on other sites More sharing options...
