viper Posted January 20, 2007 Report Share Posted January 20, 2007 Hi allI have a diamondback Viper 2006,the problem i have is that the chain keeps rubbing the rear brake unless i tighten the chain really tight,then the freewheel becomes very tight,,can anybody tell me how to resolve this ??.36/13 compact gearing if this helps....... Quote Link to comment Share on other sites More sharing options...
Wright Pads Posted January 20, 2007 Report Share Posted January 20, 2007 I'd say you need to move the chainline over to the right more at the 13T sprocket. Have you checked to see that your brake is not too far out from the frame/rim? Quote Link to comment Share on other sites More sharing options...
tom 20 Posted January 20, 2007 Report Share Posted January 20, 2007 Maybe the chainring needs moving to the center of the cranks if it suddenly goes tight in places. does it go loose tight loose tight? Quote Link to comment Share on other sites More sharing options...
viper Posted January 20, 2007 Author Report Share Posted January 20, 2007 Maybe the chainring needs moving to the center of the cranks if it suddenly goes tight in places. does it go loose tight loose tight? yes it does m8,,,,the chain is about 1/4 inch above rear break Quote Link to comment Share on other sites More sharing options...
