How To - Paint Stripping.
Phil H
use nitromorse or caustic soda if it's anadised, which i think it is? just paint it on and leave it for a bit then it should all be crumbling and falling of then wipe it down with a cloth or jetwash it you'll then need to polish it so get some auto sol metal polish and make it shiny (Y)
Yoyoyo i have paint striped a couple of frames so heres how it is>
1st!: Go to your local diy shop and get some Paint stripper/ nitromorse,rubber gloves,rags.
2nd!: Take your bike apart.
3rd!: Set a suitble area up (away from animals,small children).
4th!: Put Paint stripper/ nitromorse in a container and put rubber gloves on.
5th!: Take rag and dip it in the Paint stripper/ nitromorse and wipe on your frame, after you have aplied one coat leave the Paint stripper/ nitromorse to work for around 20-25 mins maby more, you may need to do this more than once.
6th!: Takeold brush or rag and wipe the frame down, after wiping the frame down the frame should be stripped.
7th!: You may want to spray a coat of clear laquer on the frame to give it a shine effect and also add a protection coat.
Hope it helped conor(Y)
Cheers for the response guys. I spoke to my dad about Nitromorse this morning and we have some in the garage but brought up the point it depends how/under what temperatures etc the paint was applied. Do different manafacturers have different ways of applying paint?
Anyway, I will get in touch with some people who have actually done it on T-Rex's and see if they can help.
Cheers. Phil
I just stipped my trex about a week ago it really is a piece of piss to do , just paint nitromorse allover it wait like 5 mins then the paint crumbles and you just wipe it off and wash your frame down and thats it .
your thinking way to much about it , it really is just simple and once youve done it you will agree.
