RR_Trials Posted January 19, 2007 Report Share Posted January 19, 2007 My task bar at the bottom of my screen has disapeared. I have not done anything to get rid of it as when i turn it on it is there untill some of the icons on the bottom right load up then it just disapears. I have tryed changing some of the options under control panel>task bar and start menu.Dose anybody know what to do as it is very hard to use my computer without a task bar.Thankyou in advance, Rorz. Quote Link to comment Share on other sites More sharing options...
tomturd Posted January 19, 2007 Report Share Posted January 19, 2007 ctrl + alt + delete, then go to file > new task, type in "explorer" (without the quotes) and press enter... hopefully it should reappear? Not the best solution but should/might work. Quote Link to comment Share on other sites More sharing options...
Janson Posted January 19, 2007 Report Share Posted January 19, 2007 you sure you cant get the edge of it and just drag it up to make it appear again? Quote Link to comment Share on other sites More sharing options...
RR_Trials Posted January 19, 2007 Author Report Share Posted January 19, 2007 I will try now once my computer has booted, thankyou very much.you sure you cant get the edge of it and just drag it up to make it appear again?you cant do that with XP themed taskbars, im shure of itctrl + alt + delete, then go to file > new task, type in "explorer" (without the quotes) and press enter... hopefully it should reappear? Not the best solution but should/might work.Just came up with MyDocuments, and did nothing else nothing came up at the bottom. Quote Link to comment Share on other sites More sharing options...
Janson Posted January 19, 2007 Report Share Posted January 19, 2007 go to the taskbar options and untick the box with 'lock the taskbar' next to it, then try the dragging. Quote Link to comment Share on other sites More sharing options...
RR_Trials Posted January 19, 2007 Author Report Share Posted January 19, 2007 go to the taskbar options and untick the box with 'lock the taskbar' next to it, then try the dragging.Dosn't work, its not hidden down at the bottom, because all the programs load with a space at the bottom were the task bar should be, so its tunred invisible some how. Quote Link to comment Share on other sites More sharing options...
Willy Posted January 19, 2007 Report Share Posted January 19, 2007 Try pressing F11? Quote Link to comment Share on other sites More sharing options...
tomturd Posted January 19, 2007 Report Share Posted January 19, 2007 you cant do that with XP themed taskbars, im shure of itTried going back to a default theme? Quote Link to comment Share on other sites More sharing options...
RR_Trials Posted January 19, 2007 Author Report Share Posted January 19, 2007 (edited) My defalt theme is XP i am prety shure of it because it is XP i am running. it is so frustrating that it would just disapear after being fine before i turned it off.Try pressing F11?Dosn't work. Edited January 19, 2007 by RR_Trials Quote Link to comment Share on other sites More sharing options...
RR_Trials Posted January 20, 2007 Author Report Share Posted January 20, 2007 BUMP PLEASE HELP Quote Link to comment Share on other sites More sharing options...
paolo Posted January 20, 2007 Report Share Posted January 20, 2007 What happens when you press the win key on your keyboard ? Quote Link to comment Share on other sites More sharing options...
Tomm Posted January 20, 2007 Report Share Posted January 20, 2007 I'm pretty sure you have a virus of some description. Quote Link to comment Share on other sites More sharing options...
RR_Trials Posted January 20, 2007 Author Report Share Posted January 20, 2007 What happens when you press the win key on your keyboard ?The menu list goes up but it it stays blank were it should say, start etc.I'm pretty sure you have a virus of some descriptionyou could well be right im going to scan. Quote Link to comment Share on other sites More sharing options...
Guest Posted January 20, 2007 Report Share Posted January 20, 2007 use system restore to put it back to normal??? Quote Link to comment Share on other sites More sharing options...
RR_Trials Posted January 20, 2007 Author Report Share Posted January 20, 2007 I dont wont to have to restore my computer because i can't be arsed to back up all my files. Quote Link to comment Share on other sites More sharing options...
Guest Posted January 20, 2007 Report Share Posted January 20, 2007 try xp system restore it just resets settings ad stuff doesn't delete new files Quote Link to comment Share on other sites More sharing options...
RR_Trials Posted January 21, 2007 Author Report Share Posted January 21, 2007 try xp system restore it just resets settings ad stuff doesn't delete new filesHow do i do that, ill give it a go. Quote Link to comment Share on other sites More sharing options...
Dan6061 Posted January 21, 2007 Report Share Posted January 21, 2007 You haven't got it set to 'Auto-hid the taskbar' have you? Quote Link to comment Share on other sites More sharing options...
RR_Trials Posted January 21, 2007 Author Report Share Posted January 21, 2007 You haven't got it set to 'Auto-hid the taskbar' have you?Nope but funny you should say that, when i set it to that and put my mouse down their it comes up once, but then it disapears again, and dosn't come back if i try to do it again, even if i untick autohide and retick it again.Its so crazy and random but its anoying the F**K out of me Quote Link to comment Share on other sites More sharing options...
