4 Bolt Booster With Evo Mounts?
_Owen.
If your frame only has vee brake mounts you will struggle as you have to drill/file away at the booster and use different bolts. Its do-able but it would be far easier to buy a decent v brake booster and use that and the standard magura one together.
http://www.chainreactioncycles.com/Models.aspx?ModelID=8215 is pretty good.
