gasgas Liam Posted January 18, 2007 Report Share Posted January 18, 2007 Is there really much difference bettween the t-comp and the t-pro apart from maguras? I allready have a pair of maguras to put on as soon as i get my t-pro but i just want to no whats the differenceCheers Liam Quote Link to comment Share on other sites More sharing options...
teeth Posted January 18, 2007 Report Share Posted January 18, 2007 wheelbase is all i can see compare them on tartybikes hope helped... Quote Link to comment Share on other sites More sharing options...
gasgas Liam Posted January 18, 2007 Author Report Share Posted January 18, 2007 Cheers do you know if they are the same weight??? Cheers Liam Quote Link to comment Share on other sites More sharing options...
teeth Posted January 18, 2007 Report Share Posted January 18, 2007 (edited) www.tartybikes.co.uk check for urself cheers Edited January 18, 2007 by teeth Quote Link to comment Share on other sites More sharing options...
gasgas Liam Posted January 18, 2007 Author Report Share Posted January 18, 2007 Cheers mate new to trials you see dont no any good websites either Quote Link to comment Share on other sites More sharing options...
teeth Posted January 18, 2007 Report Share Posted January 18, 2007 ah right well you will defo want to check out www.trashzen.com and www.trials-online.com there very good helped me loads cheers bud good luck riding Quote Link to comment Share on other sites More sharing options...
Muel Posted January 18, 2007 Report Share Posted January 18, 2007 Actually the wheelbase is the same aswell! they are the same frame and fork.he ony difference is the maggies I think, I think they also come with tensile freewheels on new onza cranks this year...l Quote Link to comment Share on other sites More sharing options...
Dan6061 Posted January 19, 2007 Report Share Posted January 19, 2007 Different rims, tyres, and brakes. Quote Link to comment Share on other sites More sharing options...
onzat-comp Posted January 19, 2007 Report Share Posted January 19, 2007 Hi there i have a onza t-comp and used to have a t-pro. The difference is the breaks from a normal v-break on the t-pro to a hs-33 on the t-comp. The t-comp also has drilled wheels and bling blue rim tape. It shows through the wheels. I think the onza t-comp would be the best bike to go for if you were buying it. Hope ive helped. rick. Quote Link to comment Share on other sites More sharing options...
Fixed Pantsâ„¢ Posted January 19, 2007 Report Share Posted January 19, 2007 Aren't the T-Comps lighter than the T-Pros? Quote Link to comment Share on other sites More sharing options...
JT! Posted January 19, 2007 Report Share Posted January 19, 2007 the new t-comp and the new t-pro are the same frame, bar the colour. Quote Link to comment Share on other sites More sharing options...
CrOcKeR Posted January 19, 2007 Report Share Posted January 19, 2007 Aren't the T-Comps lighter than the T-Pros?Yes they are only because of componants same frame but has drilled rims different tryes and brakes ect ... Quote Link to comment Share on other sites More sharing options...
