MadManMike Posted January 15, 2007 Report Share Posted January 15, 2007 Right,My partner drives a J reg 106 1.1 xn - Lately the indicators have been playing up, sometimes they wouldn't come on when you tried to indicate left or right, but now they've completely died and it seems to affect Hazard lights too.You press the Hazard button and you can hear a click in the fuse box like it's doing something, likewise with the indicator stalk.It seems to me like a loose connection in the wiring as it didn't suddenly go (ie it's not the fuse or the bulbs).Am I correct? If so, how easy is it to get to the cables behind the fuse box? I'm sure that's where the loose connection is, as the indicator stalk and hazard light button are not together (ie they'd both have to go at the same time - highly unlikely). Therefore I assume it's at the back of the fusebox or before they branch off to each control...Any ideas chappies?Mike Quote Link to comment Share on other sites More sharing options...
Will Arnold Posted January 15, 2007 Report Share Posted January 15, 2007 got a haynes manual? that should be able to tell you.or just start dismantling the footwell pannels. making sure u know how to put it back together, you can't go wrong Quote Link to comment Share on other sites More sharing options...
Caleb Posted January 15, 2007 Report Share Posted January 15, 2007 have you checked the fuses?if not sounds like a relay may have gone Quote Link to comment Share on other sites More sharing options...
Fixed Pants™ Posted January 15, 2007 Report Share Posted January 15, 2007 Nothing wrong with them Mike, they're meant to go on and off! Quote Link to comment Share on other sites More sharing options...
Caleb Posted January 15, 2007 Report Share Posted January 15, 2007 Fat Pants said: Nothing wrong with them Mike, they're meant to go on and off!your a c-unt, your a c-unt your a country farmer c-unt ! Quote Link to comment Share on other sites More sharing options...
Fish-Finger-er Posted January 15, 2007 Report Share Posted January 15, 2007 MadManMike said: Right,My partner drives a J reg 106 1.1 xn - Lately the indicators have been playing up, sometimes they wouldn't come on when you tried to indicate left or right, but now they've completely died and it seems to affect Hazard lights too.You press the Hazard button and you can hear a click in the fuse box like it's doing something, likewise with the indicator stalk.It seems to me like a loose connection in the wiring as it didn't suddenly go (ie it's not the fuse or the bulbs).Am I correct? If so, how easy is it to get to the cables behind the fuse box? I'm sure that's where the loose connection is, as the indicator stalk and hazard light button are not together (ie they'd both have to go at the same time - highly unlikely). Therefore I assume it's at the back of the fusebox or before they branch off to each control...Any ideas chappies?Mikeyea there on a seperate switch, so is unlikely to be the wiring in the steering column, if you can hear a clicking though, first thing id do is find your flasher relay. and swap it with another relay to see if it rectifies the issue, but that sounds the most likely cause to me, either a broken/burnt out connection in the relay, or its just sticking. Quote Link to comment Share on other sites More sharing options...
endofreak Posted January 15, 2007 Report Share Posted January 15, 2007 Definately sounds like the relay needs changing. It can be found behind the glove box. Should be easy enough to find if you can get it to click using the hazard switch. Quote Link to comment Share on other sites More sharing options...
watto Posted January 15, 2007 Report Share Posted January 15, 2007 Fat Pants said: Nothing wrong with them Mike, they're meant to go on and off!you complete and utter f**ktard if you arnt going to help the situation DONT REPLIE Quote Link to comment Share on other sites More sharing options...
Lawnmowerman Posted January 15, 2007 Report Share Posted January 15, 2007 Sounds like your indicator relay needs looking at. Quote Link to comment Share on other sites More sharing options...
Josephine Posted January 15, 2007 Report Share Posted January 15, 2007 watto said: you complete and utter f**ktard if you arnt going to help the situation DONT REPLIEI think that'll go down as my 'Overreaction of the Week™" Joe x Quote Link to comment Share on other sites More sharing options...
Davey Posted January 16, 2007 Report Share Posted January 16, 2007 Josephine said: I think that'll go down as my 'Overreaction of the Week™" Joe xI do find it amusing that if, for example, my good friend Jon had said that everyone would have laughed their arse off, but then Fatboy does make a habbit of rubbing people up the wrong way so gotta expect a bit of backlash I guess. I think it's amusing that no one likes him and he seems to actually enjoy it, haha, good for you Fatso!Davey Quote Link to comment Share on other sites More sharing options...
MadManMike Posted January 16, 2007 Author Report Share Posted January 16, 2007 Fatpants always adds something jokey to threads, just ignore it. I chuckled briefly, and just scroll past it!Thanks for your help everyone, I guess Relay has the majority vote, I shall check later I told her to sell it ages ago, it's nothing but trouble! (It's French after all!)Cheers peeps i'll let you know what happens Quote Link to comment Share on other sites More sharing options...
ian Posted January 16, 2007 Report Share Posted January 16, 2007 MadManMike said: Fatpants always adds something jokey to threads, just ignore it. I chuckled briefly, and just scroll past it!Thanks for your help everyone, I guess Relay has the majority vote, I shall check later I told her to sell it ages ago, it's nothing but trouble! (It's French after all!)Cheers peeps i'll let you know what happensot: there is nothing wrong with french cars. Quote Link to comment Share on other sites More sharing options...
MadManMike Posted January 16, 2007 Author Report Share Posted January 16, 2007 Well there is, the indicators aren't working...lolSeriously, French cars are poo compared to Jap or German.But hey, there's the car thread for arguements. Quote Link to comment Share on other sites More sharing options...
Rossi Posted January 16, 2007 Report Share Posted January 16, 2007 Yep, french cars are dier with their electrics. As said, the relay looks the fave. Quote Link to comment Share on other sites More sharing options...
