Im Havin Trouble With My Snail Cams On My Echo Hub
mattegg
hi i just have bought full set of echo wheels from tartybikes. with the 07 rims and the echo hubs. However i came to put them on to my t pro and found out that my chain was to long and therefore my snail cams would not tighten it enough. so i took a link but then it became to tight. im goin to get a new chain neway. but please may you leave comment s on how to sort out this problem as i have no idea on how to do this. picyures wud be very grateful as it makes it easier to understand. thanks matt:)
my mate has the same problem with his zoo hub which is pretty much the same as the echo and the snail cams that come with are rubbish. he is going to buy a new pair of snail cams and see if the promblem is any better
i will post again if it has been sorted
nick
I had this problem with my GU hub which is basicaly the same as the echo hub, the snail cams that came with it have a small outer diameter so there isn't enough adjustment on them. (N) Luckily i had my old snail cams which have a larger diameter (Y)
(I dont understand how the snail cams that you get with the Echo,zoo,GU,adamant ect, are ment to work as i bought a gu hub for a gu frame and i have standard ratio yet they are too small).
