PaRtZ Posted January 13, 2007 Report Share Posted January 13, 2007 20"OK after my zip has been well and truly battered (but still not broken ) I've decided I want to get a monty. Now I know Ill need a new bb because my current one has....complications but I was thinking what else will I have to change?I know Ill need:snail camsBB - What size? (see below)Rear hub maybe? ( " )Im running a profile rear cassette so will that fit? I seem to remember last time it did. Also what width bb would be good for it? im currently on 128mm gigapipe which i dont like with GU cranks, no bashringAny thing else I've missed please point out Thanks Quote Link to comment Share on other sites More sharing options...
huge Posted January 13, 2007 Report Share Posted January 13, 2007 (edited) Do you know if you'll need new forks? Steerer lengths may be an issue...I guarantee you will forget to buy new grips. Happens to me every time. Edited January 13, 2007 by huge Quote Link to comment Share on other sites More sharing options...
Greetings Posted January 13, 2007 Report Share Posted January 13, 2007 (edited) You will need a new rear hub as the Montys have a 106mm spacing. At the cost of significant loss in durability, you will be able to run a Profile by bending away the rear triangle. You might want to have it machined to fit the frame.The 128mm bb is fine, at least it was on my bike. No problems with the chain line. Another thing is if you're getting a Monty frame, you might as well get the right stem to go with it. This would either be a 221Ti (if you're rich) or a 221Pr if you have any common sense (which after looking at your profile pic I think you have). Personally I'd also get the 221 bars and have them extended to about 710mm. They have a great geometry although they are a bit narrow.If you're going to run the Profile without machining it down, drop me a PM because there are a few things you can do to stop the frame from cracking.Edit: if you're gettnig a Ti you will have no problems with steerer length, the head tube is ridiculously short and the headset goes inside it. A Pr should be similar to the Zona. Edited January 13, 2007 by Inur Quote Link to comment Share on other sites More sharing options...
ogre Posted January 13, 2007 Report Share Posted January 13, 2007 new headset? the montys run internal i think, would you be selling ones zona? got an idea how much you'd be wanting for it? Quote Link to comment Share on other sites More sharing options...
Gavyn. Posted January 13, 2007 Report Share Posted January 13, 2007 having changed from zona to pr to zona you won't need a new hub the profile fits perfectly but you need to run the snail cams on the outside.you can get away with a 118 bb with tensiles a bashring and a freewheel you may have steerer tube issues if you've cut the forks down i need 2 10mm spacers on my forks with the zona and none on the monty. Quote Link to comment Share on other sites More sharing options...
RobinJI Posted January 13, 2007 Report Share Posted January 13, 2007 (edited) Hahaha, ignore my stupidity. Edited January 13, 2007 by Dont you Just Hate it When... Quote Link to comment Share on other sites More sharing options...
Danny Kearns Posted January 13, 2007 Report Share Posted January 13, 2007 What? why will he need new grips?I'm guessing he was having a laugh, You know, Sense of humor.Dan............. Quote Link to comment Share on other sites More sharing options...
robonatomz Posted January 13, 2007 Report Share Posted January 13, 2007 you gotta get some pink grips, they are the future!rob. Quote Link to comment Share on other sites More sharing options...
Will Arnold Posted January 13, 2007 Report Share Posted January 13, 2007 echo lite....gu typhoon...DO IT Quote Link to comment Share on other sites More sharing options...
Mat Smith! Posted January 13, 2007 Report Share Posted January 13, 2007 Blue doesn't go with Monty Gerra lite .Mat Quote Link to comment Share on other sites More sharing options...
PaRtZ Posted January 14, 2007 Author Report Share Posted January 14, 2007 Blue doesn't go with Monty Gerra lite .Matlmaoyeah was thinking about that but i might be on a budgetzorz Quote Link to comment Share on other sites More sharing options...
mat hudson Posted January 14, 2007 Report Share Posted January 14, 2007 noooo, you said yourself your zona rode better than your monty. Quote Link to comment Share on other sites More sharing options...
AdamR28 Posted January 15, 2007 Report Share Posted January 15, 2007 You will need a new rear hub as the Montys have a 106mm spacing.Depends which frame - the 221 Prs are standard 110mm spacing this year.Ads Quote Link to comment Share on other sites More sharing options...
oakley Posted January 15, 2007 Report Share Posted January 15, 2007 Depends which frame - the 221 Prs are standard 110mm spacing this year.Adsplus you could just wack it in anyway and stop being a puff!you will need;headsetooo, thats it.you dont need a bb, and u dont need a new hub! Quote Link to comment Share on other sites More sharing options...
Greetings Posted January 15, 2007 Report Share Posted January 15, 2007 Depends which frame - the 221 Prs are standard 110mm spacing this year.AdsSo what happens if I run DD on a 221pr 07 with a 221Ti disc hub? The Ti has a 106mm spacing so if I put that hub into a PR the rotor will 2mm too far away from the disc tab. What hub do you use? Quote Link to comment Share on other sites More sharing options...
RobinJI Posted January 15, 2007 Report Share Posted January 15, 2007 With one of these Quote Link to comment Share on other sites More sharing options...
Christophe' Posted January 15, 2007 Report Share Posted January 15, 2007 (edited) 20"OK after my zip has been well and truly battered (but still not broken ) I've decided I want to get a monty. Now I know Ill need a new bb because my current one has....complications but I was thinking what else will I have to change?I know Ill need:snail camsBB - What size? (see below)Rear hub maybe? ( " )Im running a profile rear cassette so will that fit? I seem to remember last time it did. Also what width bb would be good for it? im currently on 128mm gigapipe which i dont like with GU cranks, no bashringAny thing else I've missed please point out Thankstry working it out yourself?thats the pleasure! actualy figuring something out ! ( like having a brain ).maybe ive got a simple 24 so its easy?its hard to know what will work with with what nowadays Edited January 15, 2007 by VillageDave Quote Link to comment Share on other sites More sharing options...
