MattB Posted January 12, 2007 Report Share Posted January 12, 2007 Hi there guysGot my friend here who's brake I'm bleeding. Basically he ran it with oil for quite a while and now he wants to switch to water. So I bleed it with water a few times and but the lever feels spongy and comes in almost to the bar. Is there something I'm missing.Thanks matt Quote Link to comment Share on other sites More sharing options...
ian Posted January 12, 2007 Report Share Posted January 12, 2007 you have got air in there matt, bleed it so it dont have air in it. Quote Link to comment Share on other sites More sharing options...
MattB Posted January 12, 2007 Author Report Share Posted January 12, 2007 We have tried that but we can't seem to get all the air or oil out and could it be that there is some oil still in there (this is ben by the way but im with matt) Quote Link to comment Share on other sites More sharing options...
super Posted January 12, 2007 Report Share Posted January 12, 2007 My advice:Boil the water, put it in an air tight container and allow it to cool.Mix with anti-freeze and bleed.Water must be cool before bleeding!!!! Quote Link to comment Share on other sites More sharing options...
Concussion Posted January 12, 2007 Report Share Posted January 12, 2007 I had this problem a while back.... I still don't know why forcing fluid through the system didn't get rid of all the air, but I just kept on bleeding it over and over again, and it eventually worked?Sorry not much help, hope someone can clear this up for next time/ can an air pocket get trapped in the lever when bleeding etc? Quote Link to comment Share on other sites More sharing options...
fredrico Posted January 12, 2007 Report Share Posted January 12, 2007 I found with using water i had to push the water through the cylinders up to the lever, if that makes sense. Quote Link to comment Share on other sites More sharing options...
trialsalot Posted January 12, 2007 Report Share Posted January 12, 2007 use a footpump or stirrup pump to blow all of the oil/water out.theres alot of it in there!!bleed the brake a couple of times close the stystem off and squeeze the lever repeatedly to get the water everywhere in the brake.then bleed again.make sure the hose is routed through any tight curves also bleed the brake from the brake to lever(syring on the brake) and raise the handle bars as vertical as possible.oh..and when your pushing water through tap the caliper,hose and lever in that order...think it may help any air shift to an out of the lever. i bled mine with a pint of water.be patient too...good luck dudecraig Quote Link to comment Share on other sites More sharing options...
Greetings Posted January 12, 2007 Report Share Posted January 12, 2007 Just get the angles right and bleeding is as easy as having a wank. There's a topic about this in FAQ. Quote Link to comment Share on other sites More sharing options...
Ali C Posted January 12, 2007 Report Share Posted January 12, 2007 if you have bled it and it still seems to have air, just do a top up......undo the lever nipple and put your syringe in there (make sure theres no air in the tube from the syringe) and pull the lever in and holdit there untill the air has gone into the syringe, once it has let the lever go and it will pull new water into the maggie, keep doing that until no more air comes out...give it a few fast pumps to make sure theres no small bubbles and your good to go.That way garrentees theres no air in the system and is easier to do than a standard bleed. Quote Link to comment Share on other sites More sharing options...
mrBENN Posted January 12, 2007 Report Share Posted January 12, 2007 Thanks for your help people but we got the problem sorted .thanks Quote Link to comment Share on other sites More sharing options...
