pitbull-91 Posted January 8, 2007 Report Share Posted January 8, 2007 Hi i have a hope mini mono and wish to water bleed it but don't know how can someone please help me, can it be bleed in a bath like a hs33?Thanks,Adam. Quote Link to comment Share on other sites More sharing options...
Ash-Kennard Posted January 8, 2007 Report Share Posted January 8, 2007 don't do it, for the love of god don't do it.they use d.o.t fluid for a reason, DON'T USE WATER IN YOUR DISC, IT WON'T WORK, AND IT WILL BE A HUGE WASTE OF MONEY!!!!ok, just use d.o.t Quote Link to comment Share on other sites More sharing options...
(chief) Posted January 8, 2007 Report Share Posted January 8, 2007 Hi i have a hope mini mono and wish to water bleed it but don't know how can someone please help me, can it be bleed in a bath like a hs33?Thanks,Adam.no don't belled it with water it will fuc* it up use there dot 5 or 4 that is all the hope mono can take.chris Quote Link to comment Share on other sites More sharing options...
pitbull-91 Posted January 8, 2007 Author Report Share Posted January 8, 2007 Thats strange i know two people with water bleed hopes and they work a treat.Adam. Quote Link to comment Share on other sites More sharing options...
flas12345 Posted January 8, 2007 Report Share Posted January 8, 2007 i would not do that mate, not at all. i had two hopes and i bled them with dot 5 oil with a seringe and that was it and they worked fine. Quote Link to comment Share on other sites More sharing options...
20inchsuperstar Posted January 8, 2007 Report Share Posted January 8, 2007 why do people water bleed brakes?water is made of H2O and the "O" stands for oxygen!!oxygen compresses leaving you with squishy brakes!!!!please just use D.O.T fluid for all reasons including the safety of the brakechoose the sensible optionmatt Quote Link to comment Share on other sites More sharing options...
Ollie Y Posted January 8, 2007 Report Share Posted January 8, 2007 why do people water bleed brakes?water is made of H2O and the "O" stands for oxygen!!oxygen compresses leaving you with squishy brakes!!!!please just use D.O.T fluid for all reasons including the safety of the brakechoose the sensible optionmattyer oxygen compresses when its in a gas form but when in a liquid form it does not compress atall Quote Link to comment Share on other sites More sharing options...
JsyJoel93 Posted January 8, 2007 Report Share Posted January 8, 2007 yer oxygen compresses when its in a gas form but when in a liquid form it does not compress atallThe man's got a point, Not too sure how it'll be for the disc but for my maggie, water has been the best thing I've done to it !!All the stories about brakes going squidgy and being a safety hazard because of the Oxygen compressing are a load of T*SS !To answer your question, just pick up a hope bleed kit and d.i.y, or take it to your local shop Joel Quote Link to comment Share on other sites More sharing options...
larrybailey~ Posted January 8, 2007 Report Share Posted January 8, 2007 it should be fine just mix anti-freeze in with the water or you will have a problem in the winter! larry Quote Link to comment Share on other sites More sharing options...
sfboy Posted January 8, 2007 Report Share Posted January 8, 2007 Nutter, you'll damage the metal pistons. Quote Link to comment Share on other sites More sharing options...
Gavyn. Posted January 8, 2007 Report Share Posted January 8, 2007 bleed it with oil it'll save it boiling and freezing Quote Link to comment Share on other sites More sharing options...
manuel Posted January 8, 2007 Report Share Posted January 8, 2007 DOT fluid is cheap as chips ... water will f**k it up. dont bother. full stop Quote Link to comment Share on other sites More sharing options...
fruitbat Posted January 8, 2007 Report Share Posted January 8, 2007 (edited) I know its already been said but DONT DO ITOil is used to keep the parts and pistons lubed. If you use water this wont happen and you will be quickly ruining a good working brake.Water shouldnt be really used in Maggies but they are a little more forgiving that Hope pistonsFrooty Edited January 8, 2007 by fruitbat Quote Link to comment Share on other sites More sharing options...
Wright Pads Posted January 8, 2007 Report Share Posted January 8, 2007 Water will not mess up any Hope system. Just boils a lot faster than DOT flid as they have differnt boiling points. Water is fine for trials. DH, XC etc Dot only!Mineral oil in Hope is a no no, every seal will expand, crack and pop and fail leaving you high and dry Quote Link to comment Share on other sites More sharing options...
Ash-Kennard Posted January 8, 2007 Report Share Posted January 8, 2007 yes god Quote Link to comment Share on other sites More sharing options...
JT! Posted January 8, 2007 Report Share Posted January 8, 2007 Water will not mess up any Hope system. Just boils a lot faster than DOT flid as they have differnt boiling points. Water is fine for trials. DH, XC etc Dot only!Water boils at 100 degrees though. If you mean evaporate, it can't becuase it's a sealed system. Quote Link to comment Share on other sites More sharing options...
moza Posted January 8, 2007 Report Share Posted January 8, 2007 Dont bleed your hope with water, that will mean it will run unlubricated, you will find it will ware out the pistons. also like others said it will boil, dot fluid is made to cope with the high temperatures brakes produce, this is why its used. also if water boils and your going down a long hill dragging you brake it will act like a closed system and because the water will make steam and your brake will jam on and you will eat the floor. dot fluid is cheap so try get some dot 5.1 it is higher quality than dot 4 moza Quote Link to comment Share on other sites More sharing options...
20inchsuperstar Posted January 8, 2007 Report Share Posted January 8, 2007 with the compression thing only saying cos i tried it and it all went wrongwater and disks goes wrong in a big waydont do itthe proper stuff, as said ,is cheap and works so why not use it?matt Quote Link to comment Share on other sites More sharing options...
tom 20 Posted January 8, 2007 Report Share Posted January 8, 2007 . If your going to do a job at least do it properly, use dot fluid ( clutch & brake fluid) same thing, works fine Quote Link to comment Share on other sites More sharing options...
pitbull-91 Posted January 8, 2007 Author Report Share Posted January 8, 2007 Dont bleed your hope with water, that will mean it will run unlubricated, you will find it will ware out the pistons. also like others said it will boil, dot fluid is made to cope with the high temperatures brakes produce, this is why its used. also if water boils and your going down a long hill dragging you brake it will act like a closed system and because the water will make steam and your brake will jam on and you will eat the floor. dot fluid is cheap so try get some dot 5.1 it is higher quality than dot 4 mozaJust to let you know this won't happen as its a rear brake, and hope brakes will not co*k up with water my mate kieran even bled his with ribena and that works extremely well and he has been running this for a while now. If water doesn't ruin a magura then why should it ruin a hope?. Anyway i am goin to bleed my hope with de-ionised water later on tonight and i shall let everyboddy know how well it works.Adam. Quote Link to comment Share on other sites More sharing options...
Alex.loves.boys Posted January 8, 2007 Report Share Posted January 8, 2007 (edited) Just to let you know this won't happen as its a rear brake, and hope brakes will not co*k up with water my mate kieran even bled his with ribena and that works extremely well and he has been running this for a while now. If water doesn't ruin a magura then why should it ruin a hope?. Anyway i am goin to bleed my hope with de-ionised water later on tonight and i shall let everyboddy know how well it works.Adam.THAT WAS HIG MAGURA YOU TITTHERE DIFFERNTSTOP BEING GAYWHY THE f**k U RUNNIG HOPE ANYWAY?YOU GOT A AVID Edited January 8, 2007 by alext Quote Link to comment Share on other sites More sharing options...
squince Posted January 8, 2007 Report Share Posted January 8, 2007 Bunch of dicks, dont take 20 people too tell him its gonna f**k his brake up. Quote Link to comment Share on other sites More sharing options...
pitbull-91 Posted January 8, 2007 Author Report Share Posted January 8, 2007 THAT WAS HIG MAGURA YOU TITTHERE DIFFERNTSTOP BEING GAYWHY THE f**k U RUNNIG HOPE ANYWAY?YOU GOT A AVIDAlex its for the rear because im going to be buying a simtra frame. Also tyler is running a hope with a water bleed and my mate james, how comes they work perfect and feel loverly?.Adam. Quote Link to comment Share on other sites More sharing options...
chris mac Posted January 8, 2007 Report Share Posted January 8, 2007 (edited) to be honest mate its not worth the hassle, if you think that water will be ok go ahead and do it but if it brakes dont come crying and complain that your brake leaks. bleed it with dot 4 or dot 5.1 to save the hassle if it does brake, it shouldnt take over 20 members to tell you that what you are going to do is rong. listen to them Edited January 8, 2007 by chris mac Quote Link to comment Share on other sites More sharing options...
pitbull-91 Posted January 8, 2007 Author Report Share Posted January 8, 2007 to be honest mate its not worth the hassle, if you think that water will be ok go ahead and do it but if it brakes dont come crying and complain that your brake leaks. bleed it with dot 4 or dot 5.1 to save the hassle if it does brake, it shouldnt take over 20 members to tell you that what you are going to do is rong. listen to them Is there anyway i can get the same feel as water?Adam. Quote Link to comment Share on other sites More sharing options...
