Wright Pads Posted January 8, 2007 Report Share Posted January 8, 2007 I've always used 32H and 3X when i have built my rear wheels. Only my mad ass DH rig had 36 as thats how it came. My new frame will be running a rear disc. Very trick custom Hope disc with lots of tweaks. Think of a Magura that has the analog feel yet more bite and grip with a TPA on the leaver just like a Magura. Anyway my set up is thisChris King Single Speed disc hubCustom Stainless Steel axleHope 200mm disc (modded)160 Caliper modedI'm unsure of what rim to rim, want soemthing big and beafy but nice looking.I'm ordeirng my new hub shell today.Adam @ Tartybikes will be building it for me as i want the best but he is also going to swap my king gubbings over to the new shell as my tool is in tut atic and i'm still in a cast.Spoke probs be Sapim race....or what wever Tart has.So 36 is ment to be be stiffer and when built 4x is really stiff.Theos here both mod and stock, what you go for? Bigman your the only man i know to of really stressed a rear disc brake to the max. What did you go for in the end?Pete Quote Link to comment Share on other sites More sharing options...
Ben Cox Posted January 8, 2007 Report Share Posted January 8, 2007 alex dx32 pete, all the time Quote Link to comment Share on other sites More sharing options...
Wright Pads Posted January 8, 2007 Author Report Share Posted January 8, 2007 alex dx32 pete, all the timeWas thinking of something wider, bigger and drilled out Quote Link to comment Share on other sites More sharing options...
Ben Cox Posted January 8, 2007 Report Share Posted January 8, 2007 koxx rims dent easy as sheet and with your extreme dropgaps you do it would last a week, maybe try the 07 echo rim? Quote Link to comment Share on other sites More sharing options...
pitbull-91 Posted January 8, 2007 Report Share Posted January 8, 2007 I would definitely go for 36hole and 4 cross, and i would also suggest getting an eyeletted rim to stop the spoke from being riped out i f a branch or a stick gets stuck in your back wheel (this hapenned to me on my dh rig) plus an eyeletted rim can be built stiffer.hope this helps, Adam. Quote Link to comment Share on other sites More sharing options...
Wright Pads Posted January 8, 2007 Author Report Share Posted January 8, 2007 (edited) koxx rims dent easy as sheet and with your extreme dropgaps you do it would last a week, maybe try the 07 echo rim?I killed an Echo 06 in 15 mins of it being built up. Cheap Deng crap that was. It went just by doing some small gaps. 07 looks wank.I would definitely go for 36hole and 4 cross, and i would also suggest getting an eyeletted rim to stop the spoke from being riped out i f a branch or a stick gets stuck in your back wheel (this hapenned to me on my dh rig) plus an eyeletted rim can be built stiffer.hope this helps, Adam.I was thinking this too but whom does an eyeletted rim these days? I know someone that can fit eyelettes to a rim if i needed it badly. 36 and 4x is what i was thinkingEdit: Just wen't to order my new shell of Bromly Bike as mark the owner said he had a black one ready for me and just o the phone there all being uber gay. 1 month and a half to order one in. Wankers @ Bromlybike is all i can say. Guess i'll have to hasstle Fatmike for one now. Edited January 8, 2007 by Wright Pads Quote Link to comment Share on other sites More sharing options...
pitbull-91 Posted January 8, 2007 Report Share Posted January 8, 2007 I killed an Echo 06 in 15 mins of it being built up. Cheap Deng crap that was. It went just by doing some small gaps. 07 looks wank.I was thinking this too but whom does an eyeletted rim these days? I know someone that can fit eyelettes to a rim if i needed it badly. 36 and 4x is what i was thinkingTry the new revell rims on tarty the look just the ticket for what you are afterheres the linkhope this helps, Adam. Quote Link to comment Share on other sites More sharing options...
Wright Pads Posted January 8, 2007 Author Report Share Posted January 8, 2007 Try the new revell rims on tarty the look just the ticket for what you are afterheres the linkhope this helps, Adam.Hexagonal shaped holes reduce the overall rim weight but also look great!Correcnt me if i'm wrong but didn't every Viz rim die due to these silly shapped holes? These just look a rip off the, and re-braneded like everything eles out there now!Revell is into dual disc frames so might be a good one to use. Might just have to get the rim drilled with normal holesPete Quote Link to comment Share on other sites More sharing options...
pitbull-91 Posted January 8, 2007 Report Share Posted January 8, 2007 Correcnt me if i'm wrong but didn't every Viz rim die due to these silly shapped holes? These just look a rip off the, and re-braneded like everything eles out there now!Revell is into dual disc frames so might be a good one to use. Might just have to get the rim drilled with normal holesPeteYes i think round holes are stronger because the stress is equal where as the hexagonal holes have corners where the stress will be worse, but other than that the rims are eactly what you are looking for just give them ago and if you can get them drilled to round hols do that. also put up a review after using them as they are new. Quote Link to comment Share on other sites More sharing options...
Wright Pads Posted January 8, 2007 Author Report Share Posted January 8, 2007 Yes i think round holes are stronger because the stress is equal where as the hexagonal holes have corners where the stress will be worse, but other than that the rims are eactly what you are looking for just give them ago and if you can get them drilled to round hols do that. also put up a review after using them as they are new.Need to find someone willing to drill them 1st. Probs do some noice big holes to lose a lot of that weight. Send them back to Tarty to be built and then give the review.Will get Tart to grind it then i can say how good they are at both disc and Magura as i can run a test with my pads on there!Cheers Pitbull...pending a driller these might be the rim to go for Quote Link to comment Share on other sites More sharing options...
pitbull-91 Posted January 8, 2007 Report Share Posted January 8, 2007 Need to find someone willing to drill them 1st. Probs do some noice big holes to lose a lot of that weight. Send them back to Tarty to be built and then give the review.Will get Tart to grind it then i can say how good they are at both disc and Magura as i can run a test with my pads on there!Cheers Pitbull...pending a driller these might be the rim to go forNo worries pete anytime, hope you are able to get them drilled out so we can all find out what they are like to ride(Y).Adam. Quote Link to comment Share on other sites More sharing options...
Wright Pads Posted January 8, 2007 Author Report Share Posted January 8, 2007 No worries pete anytime, hope you are able to get them drilled out so we can all find out what they are like to ride(Y).Adam.Gonna give Bigman a txt as not sure if he's back in uni or not. See what he says but if not i have 2 others i can ask and then i guess i can publicly post here asking.Why can't manafactures get it right 1st bloody time. Copy cats the lot of em.Mind Adam might pass this and as he is stocking the rims he must be happy enough with them or soemthing....i'm kinda borderline on that though mindPete Quote Link to comment Share on other sites More sharing options...
manuel Posted January 8, 2007 Report Share Posted January 8, 2007 (edited) the 07 echo / zoo rims are not wank ....Ive got the 07 front rim on the back of my bike... which is doing pretty darn well at being super strong and true... equivalent to a DX32 it seems to me.. (and a shade lighter)so if you want a really really strong rim get the 07 rear rim. as thats even beefier...anyone who busts those up regularily is either fat or stupid or both. Edited January 8, 2007 by manuel Quote Link to comment Share on other sites More sharing options...
Wright Pads Posted January 8, 2007 Author Report Share Posted January 8, 2007 the 07 echo / zoo rims are not wank ....Ive got the 07 front rim on the back of my bike... which is doing pretty darn well at being super strong and true... equivalent to a DX32 it seems to me.. (and a shade lighter)so if you want a really really strong rim get the 07 rear rim. as thats even beefier...anyone who busts those up regularily is either fat or stupid or both. Rowen your in a leage of your own with how you ride. I'm wary of anything thats off Deng to be fair! I killed the 06, the 07 looks odd. Quote Link to comment Share on other sites More sharing options...
Gavyn. Posted January 8, 2007 Report Share Posted January 8, 2007 They look odd but they really are loads stronger . Quote Link to comment Share on other sites More sharing options...
Wright Pads Posted January 8, 2007 Author Report Share Posted January 8, 2007 They look odd but they really are loads stronger .What des exactly...the mum down the road or . . . . ? Be more persific with your answers as we've spoken about 4 differnt rims in here off 4 differnt manafactures Quote Link to comment Share on other sites More sharing options...
ian Posted January 8, 2007 Report Share Posted January 8, 2007 the reson trials rims are weak is because of the holes in the rims plus they dont have eyelets.what is the point on buying a revel rim and drilling the holes bigger therefor making the rim weaker?im not having a dig but when you destroy the rim and says its weak then there must be a reason for it i.e you drilled bigger holes or the wheel build was never checked for spoke tension everynow and agian or even not built strong enough the first time, Quote Link to comment Share on other sites More sharing options...
Andeee Posted January 8, 2007 Report Share Posted January 8, 2007 Your best off running a rear 26 for strength in stead of running a crappy 32 that you would use on the front because the 32 is for lightness. Andy Quote Link to comment Share on other sites More sharing options...
Wright Pads Posted January 8, 2007 Author Report Share Posted January 8, 2007 the reson trials rims are weak is because of the holes in the rims plus they dont have eyelets.what is the point on buying a revel rim and drilling the holes bigger therefor making the rim weaker?im not having a dig but when you destroy the rim and says its weak then there must be a reason for it i.e you drilled bigger holes or the wheel build was never checked for spoke tension everynow and agian or even not built strong enough the first time,Look at the rim, the style of holes are known to fail as any hole in that placment should be round! I was only going to drill them so they where round by adding 2/3mm extra OD. Perfectly safeYour best off running a rear 26 for strength in stead of running a crappy 32 that you would use on the front because the 32 is for lightness. AndyI know thus, front are single walled and rears doubble Quote Link to comment Share on other sites More sharing options...
Andeee Posted January 8, 2007 Report Share Posted January 8, 2007 Look at the rim, the style of holes are known to fail as any hole in that placment should be round! I was only going to drill them so they where round by adding 2/3mm extra OD. Perfectly safeI know thus, front are single walled and rears doubbleDont get cheeky son didnt realise i put 26. Quote Link to comment Share on other sites More sharing options...
chrishayton Posted January 8, 2007 Report Share Posted January 8, 2007 What des exactly...the mum down the road or . . . . ? Be more persific with your answers as we've spoken about 4 differnt rims in here off 4 differnt manafacturesit was clear what he ment, dont be a pedantic arse. The 07 echo rims are very strong. the spank rims are very strong although only 40mm wide (and discontiued so may be hard to find.) try alls are ok but i found mine flatspotted easily. and the revells appear identical but with different shapped holes. Quote Link to comment Share on other sites More sharing options...
Ben Cox Posted January 8, 2007 Report Share Posted January 8, 2007 and yet no one has bothered questioning how the f**k pete is getting a competely custom made hope disk brake made for him? with tpa's and tweaked this n that? i smell another pete wright story....Ben Quote Link to comment Share on other sites More sharing options...
Alex.loves.boys Posted January 8, 2007 Report Share Posted January 8, 2007 and yet no one has bothered questioning how the f**k pete is getting a competely custom made hope disk brake made for him? with tpa's and tweaked this n that? i smell another pete wright story....Benwhats the pointitll just turn into another rantyou know it will benlove you really :$ Quote Link to comment Share on other sites More sharing options...
GTF Posted January 8, 2007 Report Share Posted January 8, 2007 What about the new Revell rims? Quote Link to comment Share on other sites More sharing options...
Ben@LeicesterTrials Posted January 8, 2007 Report Share Posted January 8, 2007 whats the pointitll just turn into another rantyou know it will benlove you really :$Yeah but it'll be a funny rant Quote Link to comment Share on other sites More sharing options...
