ian Posted January 7, 2007 Report Share Posted January 7, 2007 right, ive got 165 bb7's front and rear,im running clarkes cables frotn and rear with avid SD7 levers.my problem is they arent bitting as good as my old BB7's have been and before i was running cheap levers and cheapo cables and my old 160 was much better.the difference bettween my old BB7's and my new ones seem to be the rotor, now i have some roundagon rotor where as before i had a rotor with alot more holes in,is it the rotors that are the problem or something else, ive set them up correctly and even had my boss at bike shop take a look and he has said it may have something to do with the rotors.ive tried the old trick of pouring water on them when they are hot etc but this has had no effect.please help!cheers ian Quote Link to comment Share on other sites More sharing options...
Balman Posted January 7, 2007 Report Share Posted January 7, 2007 ian mate just get some lesson or hope rotors like myself look in my post about rotor and see what comes up with a bit of luck some one will come up with a crazy one off rotor that works really well or some thing like unherd of keep an eye out mate and i recon it is the rotors myself there brand new pads and brakes.cheers Jack Quote Link to comment Share on other sites More sharing options...
Balman Posted January 7, 2007 Report Share Posted January 7, 2007 (edited) sorry its posted twice Edited January 7, 2007 by jackbalman Quote Link to comment Share on other sites More sharing options...
GlynnP Posted January 7, 2007 Report Share Posted January 7, 2007 Hey Ian just to help people and comfirm which rotor do u have1:2:Second 1 is the rotor i have Quote Link to comment Share on other sites More sharing options...
ian Posted January 7, 2007 Author Report Share Posted January 7, 2007 i have the 2nd rotor. Quote Link to comment Share on other sites More sharing options...
Orgun_Donor Posted January 7, 2007 Report Share Posted January 7, 2007 im running the second rotor and its working fine, but mine is a 203 on a stock..... so i guess that doesnt help that much Quote Link to comment Share on other sites More sharing options...
Dan6061 Posted January 7, 2007 Report Share Posted January 7, 2007 Sure your rotor's not contaminated?(if you have one), Put it in the dishwasher overnight. I had one of those roundagon rotors, and changed to a Hope Gothic - As it looks better. Brake was soo much better. Quote Link to comment Share on other sites More sharing options...
ian Posted January 7, 2007 Author Report Share Posted January 7, 2007 im not joking these brakes are like 2 weeks old i fitted them only touching the middle of rotor and havent touched them since. except rode them which no luck as the braking power is useless Quote Link to comment Share on other sites More sharing options...
mat hudson Posted January 7, 2007 Report Share Posted January 7, 2007 i hasve a 203 on my stock with that rotor and its perfect. 203 on a stock is less leverage than a 160 on a mod. Quote Link to comment Share on other sites More sharing options...
RobinJI Posted January 7, 2007 Report Share Posted January 7, 2007 Yeah, there's a good change it is the rotors, the higher surface area means a lower pressure is exerted between the pads and rotor, so the break doesn't work as well, well according to leeson that's how it works. It also has a lot to do with the build of the rotor, but I can't remember how. Just get some nicer rotors, like some hopes or Hayes.My free ride bikes breaks work much better with the Hayes rotors than they ever did with shimano deores. Quote Link to comment Share on other sites More sharing options...
Damon W Posted January 8, 2007 Report Share Posted January 8, 2007 i had no.2 at first as it came standard with the brake...worked AMAZING had no bite but cudnt make it slip, hold was ridiculas ......then cos it has about 6 arms it bent,bukkled and finally snapped... then i bought roter no 1 the cleansweep becuase alot of peeps i knew had them and theres worked good and its stronger...but...my brake was neva as good with this roter on, i was always havin to apply water to it, becuase it started slipping all the time Quote Link to comment Share on other sites More sharing options...
ian Posted January 8, 2007 Author Report Share Posted January 8, 2007 both brakes are slipping all the time, i need a definate answer really as dont wanna splash out like £50 on new rotors to still have the same problem,i have always been led to believe that you have loads or holes because it stops the pads glazing and over heating. Quote Link to comment Share on other sites More sharing options...
RobinJI Posted January 8, 2007 Report Share Posted January 8, 2007 In my opinion you're gunna get the best results from a pair of hope rotors. Leeson or hope originals. But I've always liked the old style M4 rotors the best. Quote Link to comment Share on other sites More sharing options...
ian Posted January 9, 2007 Author Report Share Posted January 9, 2007 what about the hope gothic rotors? and are they the new m4 rotors? Quote Link to comment Share on other sites More sharing options...
Dan6061 Posted January 9, 2007 Report Share Posted January 9, 2007 Pour some water on them, ride around with the brake rubbing untill you see it steaming, then pour more water on. Quote Link to comment Share on other sites More sharing options...
ian Posted January 9, 2007 Author Report Share Posted January 9, 2007 Pour some water on them, ride around with the brake rubbing untill you see it steaming, then pour more water on.been there done that and it isn't doing anything at all. Quote Link to comment Share on other sites More sharing options...
RobinJI Posted January 9, 2007 Report Share Posted January 9, 2007 (edited) what about the hope gothic rotors? and are they the new m4 rotors?Hope gothic rotors are awesome aparently, cirtainly look it, but i think they have to be one off due to some kind of copywright.The Old style M4 rotors are different to the newer ones.Old M4:Gothic:Newish Mini:Latest M4:THIS is what you'd need for your breaks, if you wanted the old M4 style ones. As the actual old M4 ones only come in 165/185/205, but they did this to fit other breaks that use 160 or 203.Edit: Just noticed, your profile still says stock by the way. Edited January 9, 2007 by Dont you Just Hate it When... Quote Link to comment Share on other sites More sharing options...
loffa Posted January 9, 2007 Report Share Posted January 9, 2007 It's not a problem with your rotor, unless you have got any oil on it. I had the same problem with mine. Xtr lever, cable and hosing and a 203mm bb7 on the front of a stock bike and I could not get it to work properly. It was okay, but compred to my mates 185mm it didn't bite at all. I tried everything, cleaning the rotor and heating the pads in an oven then bedding it in again but with no luck.So finally I got new pads from my LBS and since then it has been the best front brake ever. I suggest you to concider buying new pads aswell before you fork out the £50 for new rotors. Even if they don't make a difference, then atleast you have new pads that you can throw right in when your old ones wear out. Quote Link to comment Share on other sites More sharing options...
ian Posted January 10, 2007 Author Report Share Posted January 10, 2007 me and my boss were looking at them and it turns out that the pads are fine it is just the rotors are scrubbing the first coat of the pads like the glaze on them, gonna ring hope and see if i can get osme gothic rotors through work etc. ill kee p you all informed.ill edit my profile now aswell Quote Link to comment Share on other sites More sharing options...
Ali C Posted January 10, 2007 Report Share Posted January 10, 2007 I have the new hope m4 rotor and its mint! the braking band fits avid bb7s perfectly and my brake is amazing.Before that I had reall trouble trying to get it to work, I tried loads of pads and a few rotors, I eventually got that rotor as well as some organic avid pads and it was the best thing I ever did! Quote Link to comment Share on other sites More sharing options...
ian Posted January 10, 2007 Author Report Share Posted January 10, 2007 I have the new hope m4 rotor and its mint! the braking band fits avid bb7s perfectly and my brake is amazing.Before that I had reall trouble trying to get it to work, I tried loads of pads and a few rotors, I eventually got that rotor as well as some organic avid pads and it was the best thing I ever did!so Ali did you have same problem as what i have described then? hopefully you did and you are now my savior. Quote Link to comment Share on other sites More sharing options...
