Ali C Pads
python
hi dose any boady no if you can use ali c pads on a medium grind?
hi yes you can use ali c pads on a medium grind when i was testing out for him i found that they worked best on a medium grind seen as though a harsh grind wore them down quick but not quick as in pul the brake and there gona over a few weeks i mean. they have great hold and grab on a medium grind and last longer to (Y) they will be the best pads you will of every had.
chris
