V-brake On A Magura 4 Bolt Mount? Adapter?
Mod Man Leo
Yes. They're £29 from www.Heatsinkbikes.com
You could get HS33's for that price 2nd hand from FS/WTD section, but, if you do contact someone selling them, there's a likely chance that they wont sell it to you incase you're not trust worthy.
Damn you Dan!
Edited by Fat Pants
i was wondering if i could get a V-brake on my four bolt magura mountings (till i get money for hs33).
my m8 said there is an adapter made by gusset but i cant find it...
is there a adapter avalible?
Thanks.
hey mate, i use one but mines from Heatsink its much better than any other one i have used and its a wee bit lighter!!! dont even try to use an onza one its crap!! lol but the heatsink one costs a bit more but its so worth it folow the link to have a look [topic=http://www.heatsinkbikes.com/?p=veeadapters]Link!!!
hope it helps!!
Johny
well get hold of a old vee booster (tekro one) first cut the top of the booster of so you are left with to side parts what should have to gaps so you
can screw into your frame.Then get two vee bossers and two bolts so they can tightin on the thread of the vee bossers
then get two washers and drill three small holes for the spring on the vee brake and your sorted to put vees on ur four bolt mounts
biddle
if you want more info or pictures of a vee adaptor add me to msn
biddle20@hotmil.co.uk
I have just got a set of Onza vee adapters (like heatsink) they are awsome, they have a much lower profile than the heatsink ones, and should be cheaper, only thing is that they are not availiable to buy at the moment, but i was lucky enough to find a guy with a t-pro selling some.
Before i had these i made some, they worked very well, the only real problem with making them is finding someone with the correct tap for the vee bosses, as it is a funny size (M10 x 1.25).
If you can find someone who wants to sell a set of onza adapters (i may have a set fo sale....) or u can make some/get heatsink ones i would stick with a rear vee, they ROCK
Adam
